Question about Frigidaire Washing Machines
My frigidaire twin tub washer FWLT1161FDUHWT spin tub stop working what could be the problem
The spin tub don't work it was working fine at the second spin stop and don't want to work again. The serial # 34210244 is a frigidaire acqua twin 11 kg
  • Frigidaire Master
  • 5,420 Answers
Hum what do u mean spin tub no such thing? do u mean the drum does not spin?
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
My frigidaire twin tub washer FWLT1161FDUHWT spin  - 25691063-hq4k3xnttsgicnyjnrabh2eb-4-0.jpg
25691063-hq4k3xnttsgicnyjnrabh2eb-4-4.jpgMy frigidaire twin tub washer FWLT1161FDUHWT spin - 25691063-hq4k3xnttsgicnyjnrabh2eb-4-7.jpg"/uploads/images/25691063-hq4k3xnttsgicnyjnrabh2eb-4-7.jpg" alt="256910My frigidaire twin tub washer FWLT1161FDUHWT spin - 25691063-hq4k3xnttsgicnyjnrabh2eb-4-11.jpg="h_mi" />
My frigidaire twin tub washer FWLT1161FDUHWT spin - 25691063-hq4k3xnttsgicnyjnrabh2eb-4-22.jpg/images/25691063-hq4k3xnttsgicnyjnrabh2eb-4-16.jpg" alt="25691063-hq4k3My frigidaire twin tub washer FWLT1161FDUHWT spin - 25691063-hq4k3xnttsgicnyjnrabh2eb-4-29.jpg />
Posted on May 11, 2015
Frigidaire front load washer will start and after about 2 seconds will stop. Lights will go from normal working to no spin
From what you have described I would have a professional diagnose the unit's timer and main control board for possible replacement of those parts.
Aug 31, 2012 | Frigidaire FTF2140FS Front Load Washer 10...
Washer spins slowly and will not drain
Sounds like the motor might not be turning the tub at high enough RPMs
Aug 08, 2012 | Frigidaire FEX831CS Top Load Stacked...
My FWSB5700DS0 top load washer can't get up to speed in the spin cycle. It spins up for a 5-7 seconds and before reaching full speed, it stops spinning, and the pump stops pumping. Then after a 10-15 ...
It sounds like the motor is going out. The motor will shut down when it gets to hot and once it cools it will try to work again. Motors are around $150.00 on the average. You can look at the motor and get the part number off of it and then look on eBay and find one a little cheaper.
Nov 20, 2010 | Frigidaire FWSB5700DS Top Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
We have a Frigidaire FWTB59RGSO front load washer. The fast spin cycle is not working properly. The shocks on the bottom were replaced because they were broke. The problem has not gone away. It is...
I have a front loader washer # fwtb59rgso and it wont spin or agatate, everything else works fine. feels like normal drag on the drum when I try to rotate it. Any ideas what could be wrong?
Nov 28, 2009 | Frigidaire Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Non-spinning washer
Have you checked the motor? Make sure that the motor is turning properly and also make sure that your belt it not to tight. It should have some give in it. If none of that works then look at the main bearing under the pulley on the drum
Feb 10, 2009 | GE WNSE6280BWW Top Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
134 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
