Question about Oster 12-Bottle Wine Cellar - Black
Model OW0912h6h I am trying to locate the main control board located in the back up at the top where to purchase or a part #
Posted by Rick Cantleberry on
DEFROST TIME CLOCK GE GSH25J, WHERE IS IT LOCATED?
Hello:
Your model does not have defrost timer, instead the defrost is controlled by Main control board located on the back of the fridge..
Part # WR55X10942
PS.. Most common defrost problem on this model is not the board. Its either defrost heater or defrost thermostat..
Jul 15, 2017 | GE Refrigerators
Where is main control board located on kitchenaid kbfs22ewms9 refrigerator
I haven't seen the exact model of this refrigerator byself but mostly main pc boards in old model refrigerators back bottom near left side of the compressor... Otherwise you can find on top surface or in the middle of back of the refrigetaror.. That pc board will be covered in plastic box
Oct 15, 2016 | KitchenAid Refrigerators
Model 596.66952401 I need too order a timer for my fridge where is it located so i can replace it?
Your model has the timer built into the main control board. See item location 5 in photo=> HERE
Part number=> Main Control Board WPW10503278
APPLIANCE 911
Mar 08, 2016 | Kenmore Refrigerators
Duet model WF w 93515 w 00 code F1e2
An F1E2 error code is a motor control unit error. The main control has detected that the motor controller is not doing something right. Sound funny, I agree but this is what the manufacture tells me. I assume the washer has been working fine and then this pops up? The checks for this is to find the motor controller at the bottom of unit and locate the wiring to it. Unplug washer and then unplug each wiring harness and plug back in. Test. If problem still exists, then locate the main control at top and do the same. Unplug wires, and test again. If still issue, the its a 50/50 guess, between motor controller and main board. I don't like this code because I can only go so far then I have to take a guess. Sorry.
Nov 27, 2015 | Washing Machines
Where is the main control board located on a Samsung model number rf217acrs
On the back behind a protective cover or under the back bottom section enclosed inside a protective cover.
Main Control Board DA41-00695A
Appliance 911 Sea Breeze
Nov 17, 2015 | Samsung Refrigerators
Main control board
Kenmore model number looks like this 795.51313012 90364894-0494-4d01-a2bd-9abc6a90a2c6.jpg
I am here should you need me, Thanks John Tripp Appliance 911
Apr 23, 2014 | Kenmore Refrigerators
Hi, I have a Canon iR c2550i printer and it does not start up and gives error Code E000748-4000 and directs to shutdown. What is this error about and please suggest me a method to overcome the this error.
This is a main controller issue, try disconnecting and reconnecting all components/wires connected to the main controller, it could be a Faulty RAM or image processing board, if you have 2 RAM Sticks try using one at a time to diagnose the fault, remove any dust from all boards connect and its locators. Main controller board is located at the back of the device top right. Good Luck hopefully just a build up of dust on the components
Sep 13, 2013 | Canon Office Equipment & Supplies
Kenmore 253
Your Kenmore freezer is made by Gibson (Frigidaire) Your model number for your freezer is 253.24092102 I believe the problem is a defective 216979700 Main Control Board Look over the 216979700 Main Control Board for signs of burn marks or heat damage. Sometimes you can see damage but not always.I need you to do a few things when you see the freezer defrosting like this. Feel the top of the compressor and see if it is becoming extreemly hot while it stops freezing and begins to melt the ice in the freezer. Here is a photo of the=> 25324092102-Compressor-Components Should your freezer compressor location number 29 in that photo be getting hot it could be a defective 216649315 Relay and Overload Kit location number 30 in that photo is the 216649315 Relay and Overload Kit Location number 55 in that photo is the 5304464438 Run Capacitor If the motherboard looks OK but the compressor is getting hot and trying to start and stop (short cycling) I would begin by first changing the 216649315 Relay and Overload Kit and the 5304464438 Run Capacitor If you could respond by answering my post I believe I will be able to help you solve this. I am here should you respond, Thanks Sea Breeze
Jun 27, 2013 | Kenmore 20.6 cu. ft. Top Freezer...
Model psc23sgpass GE Profile freezer and frig do not get cold enough. I have already cleaned the condenser and defrosted the freezer. We seem to have determined the evap dc fan motor is not running. But I...
The fan is controlled thru the main control board located on the back of your refrigerator. Pull unit away from the wall and you will see a metal plate. The board is located there and you will need to replace the board. This is a common problem with the GE's. The board is pricey but better than a new refrigerator. If an appliance company told you the fan was bad you should try and get them to refund the fan. wr 55x10942 is the number you need.
May 28, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Where is the defrost timer located on a G E side by side frig?
Your fridge does nt have a defrost timer. For the model PSS26MSRSS you will need a main board linked below.
Thanks for asking.
Main board
May 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Oster 12-Bottle Wine Cellar - Black Logo
305 people viewed this question
Top Oster Furniture Experts
Tom Chichester
ray gallant
Are you an Oster Furniture Expert? Answer questions, earn points and help others
