The resistor on the top left of the circuit board is bad. It has a 4-band code but it got hot enough that some of the colors are difficult to be sure of.
A lot of these digital timers have same problem with the L1 and L2 resistor... but careful inspection usually reveals that several other parts also have blackened solder connections, indicating that the entire circuit board is burned.
Scroll down a bit on following ink:
http://waterheatertimer.org/Timer-caught-fire.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
Often people ask for a schematic or for method to identify the resistor, but I have not found any resource from any of the manufacturers.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Question regarding convergence resistors
yes those two resistors are also 3.9ohm 2watt 5% resistors
SOURCE: Toshiba 55h70 schematics
you can get the entire service manual emailed to you from the following link.
http://servicemanuals.vstore.ca/
SOURCE: I need to identify the
The resistor you see is a 2.2 ohm 2 watt resistor and is part of the convergence circuitry. I would replace R7011. 7012, 7013, 7014, 7015 & 7016 (all the same value) and the 2 STK392-110 Convergence ICs. This should fix your problem. You can find kits on-line for around $45 with the IC's and resistors together.
SOURCE: RCA model R61WH76 Chasis itc222 has 3 color curved band lines on
Your model doesnt have convergence ICs. You can get the replacement parts and free instructions on how to do the repair at the following link, just click on the contact us link on the lower left hand side of the website and tell them the model number and chassis they respond quickly.
SOURCE: JVC AV56wp74 convergence. Resistor before ICs?
It's recommended to replace all the defective parts first because if you only replace the defective resistor, it might burnt again if the convergence IC is shorted internally. I would also suggest to measure the other low value resistors with multimeter.
Testimonial: "Thanks! I'll just replace everything. I was leaning on starting new anyway. Thanks for the fast response!"
