1) Adjust the reed switch , clean it, and tigh the wires connector
see the diagram
2) RUN the software calibration after you fix it, for diagnose, troubleshooting , fix it.
3) test the fuse for blown and replace, use the VOM, or c.breaker reset.
4)test the input voltage motor, with a VOM , if there are voltage, the motor need attention. tight any wires connector to the motor very well see the diagram
5) measure the output voltage board, for input voltage motor, if there are NOT voltage , the board is faulty. tight any wires connector for loose, or bad contacts. see the diagrama
IF doesnot resolve the problem call to the suppliers for warranty of the board of another parts, or service.
God bless you
