Question about Samsung Cell Phones
When you Galaxy Samsung Say Not registered on network when you trying to call someone How to fix that
Posted by DujaunHolmes on
Rhonda Webster
  • 978 Answers
According to WikiNix.com:
Step 1:
First, go to Settings.
Step 2:
Then go to Wireless and networks.
Step 3:
Then Tap Mobile Networks (If mobile networks not found then tap More settings and then find and tap Mobile networks). Watch video to understand and solve this issue easily.
Step 4:
Now tap Networks operators.
Step 5:
After complete searching.... Then select your Network Operator (Like Vodafone, Idea, AirTel, etc.)
That's it, problem solved.
Updated Fix 1. In Mobile Networks, set Network mode as WCDMA only and restart your phone. After restarting, follow above steps. That.s it (Updated on 12 September 2014). "
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Posted on May 10, 2015
4 Related Answers
Rudi Terry
  • 89 Answers
SOURCE: I have a problem in
Try to reset it to factory settings, if it does not help upgrade the firmware or if you recently upgraded the firmware downgrade it.
Posted on May 23, 2011
francis joan
  • 1696 Answers
SOURCE: ive bought a samsung galaxy
You can get the SIM network unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Posted on Jul 29, 2011
Regina Thomas
  • 4 Answers
SOURCE: i cant get a network signal on my phone its a samsung galaxy s 5360 how do i fix this ive tried sim and all usual t
turn off WIFI; reset network settngs; make sure cellular data is turned on by going into Settings>network>mobile networks>mobile network>make sure this has a checkmark. call carrier and have them cancel the registration on your phone. call them from a different phone and have your Galaxy turned off .
Posted on Oct 19, 2012
mobil master
Computer Repairing
  • 14641 Answers
SOURCE: my samsung galaxy s111 says network not registered whie making a call
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Oct 31, 2012
Why am i getting a message on my phone saying not registered on network
hi wendy.
not sure if this is what you are after its all i could find,if this does not help you then go to the link at the bottom.
What to do when your phone says not registered on network? Make sure you are connected to a Wireless connection:
  1. First Get Your Galaxy up and running, charged and ready.
  2. Put the SIM card in phone.
  3. Navigate to Settings of your Phone.
  4. Scroll down to reach the extreme bottom.
  5. Select Software Update.
  6. Wait for it to reboot and complete the update.
  7. Finished!
7 Ways To Fix Not Registered On Network on Android - Technobezz
https://www.technobezz.com/fix-samsung-galaxy-registered-network/ Search for: What to do when your phone says not registered on network?
message on my phone saying not registered on network Google Search
Nov 06, 2017 | Cell Phones
Phone not registered on network
Two things 1) enter settings and look for carrier and or network make sure it is switched to manual. Look for your network that you will to connect.i.e. EE or O 2 then select it.if it still doesn't connect. You may have an old sim which no longer useable or the phone's internal arial is not picking up signal or you are too far away from a mast.get a new sim try from a different location.a quick check is to dial 112 which is emergency services which will work anywhere without a sim but tells you the aerial is okay.but don't just hang up because they can pinpoint your location with gps and still send out someone so tell them it was a miss dialled number.
Sep 23, 2014 | www.cells4u.com Samsung Galaxy Fame S6810...
I have a Samsung Galaxy Note. Suddenly, it does not recognise any SIM card. When I try to make a call, I get a message 'Not Registered on Network'. I have also notices that when I hold the power button, I...
More than likely your IMEI number is removed or missing. Dial *#06# and if it isnt displayed or says null then thats why.....or could be you need a new sim card reader but id bet its the IMEI number removed. Thats what i am dealing with now.
Aug 09, 2013 | Samsung Galaxy Note N7000 16GB Unlocked...
Has your phone been unlocked? if not try unlocking it
May 10, 2013 | Samsung Galaxy S Duos S7562 White Dual SIM...
Samsung Galaxy s 111 not registering on network
help me register my galaxy s111 to the net work please
Nov 20, 2012 | Samsung Galaxy S 4G Cell Phone
Phone cannot connect to network
My Samsung GT-18160 has no network connections. No incoming or call out's
Nov 17, 2012 | Samsung Galaxy Y Gt-s5360 - White unlocked...
Samsung galaxy gt-s5360 network unavailable
First Option:
Secend Option:
Sep 20, 2012 | Samsung Galaxy Y Gt-s5360 - Black unlocked...
How do I unlock a samsung galaxy s.
Try code from Online site and UNLOCK IT......
Sep 19, 2011 | Samsung Cell Phones
H0w do you get unlock code for samsung galaxy s it keeps saying not registered.
You can get samsung galaxy s unlock code from your network provider, just call your network customer service and make request about samsung unlock code. To doing that process you must have a good standing account with them otherwise you will not get that code. Other solution, you can buy unlock code from third party sites. I hope my solution can solve your problem.
Jul 12, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cell Phones Logo
1,324 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
