You need to do a firmware update. Get the machine ip address. Login, default is admin as the username. I get my firmware on the My-Ricoh site but you 'll need to be registered on that site. Call your local Ricoh agent to come do a firmware update on the machine. Alternatively you can download a scan to pdf program and then go to google and type MP1600 network twain driver. But the machine needs to be connected to the network. It's a network printer.
SOURCE: Steps to install RICOH 2045eSP printer, scanner, copier to network computers
ok.. please kindly wait.. i will re construct a procedure for you..
BTW.. your network was wired or wireless?
SOURCE: lexmark 2600 installed works perfectly
does the Dell have current vista drivers set?
http://tinyurl.com/6qcpgy
SOURCE: lexmark 2600 working well as copier but error USB cable to dell computer
hmmm...that is a bit odd..
does the 2600 work in standalone mode?
SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: we have a network ricoh
please go to www.ricoh.com and instal the scanner drivers of windows-7 other wise you can instal the scan to folder which dos not required any drivers or you can install scan to mail this also does not required any drivers - thanks
