Question about Honda Karcher G2400HH-R Pressure Washer
Water pressures varies from high to low. Not idling right
Posted by Keith Butler on
Bill Boyd
    Top Expert:
  • Honda Master
  • 53,814 Answers
Checked for a problem nozzle, low inlet water pressure to the pump or faulty pressure regulator.
Posted on May 10, 2015
2005 chevy colorado fuel pressure. Increases +5 when started, drops 2 with throttle snap, no change at high idle. Is this normal?
To some extent the fuel pressure will vary depending on the depression inside the intake manifold. The fuel pressure regulator is set to produce a small range of pressures. At high manifold depression the lower pressure will be available and at low depression (throttle wide open) the fuel pressure will be at the highest.
This is the way the fuel/air mixture is richened so the engine will accelerate smoothly.
May 06, 2018 | Cars & Trucks
What is means po961 exactly
PO961Is Pressure Control Solenoid A Control CKT Range/Perf.
Feb 25, 2015 | 2004 Chevrolet Monte Carlo
OIL LIGHT KEEPS FLICKERING WHILE IDLE
Most likely your sensor is too sensitive and detects the low oil pressure that exists in idle .... you oil pump is not functioning fully and at idle fails to produce the right pressure. Lastly,your idle could be set too low. try increasing the idle slightly (you don't want it too high) and see if that solves the flickering light problem
May 30, 2014 | 2004 Ford Escape
Oil gauge drops low at idle
Low oil pressure at idle can be caused by an engine with worn rod or main bearings due to (usually) high mileage . This however does not mean the engine is still not serviceable as long as the oil pressure is low only at idle. The pressure should at minimum get into the normal range at anything above idle speed.Not much oil pressure is really necessary at LOW speed. At low speed, as long as there is oil getting to the bearings, even at low pressure, you are OK. In a high mileage engine the oil pressure is often low at idle simply because the oil pump is turning slowly and cannot maintain higher pressure between the larger than normal crankshaft and bearing clearances. As speed increases the pump turns faster and supplies more oil and the pressure should go higher. Low pressure as long as it is only at idle is not a problem. However at higher speeds the pressure should be in the normal range. Such a worn engine can benefit from higher viscosity (thicker) oil such as 20W-50 in above freezing weather and 10W-40 in winter. That will increase idle pressure and the thicker oil film maintains a better film between the worn parts
Apr 08, 2012 | 2002 Jeep Grand Cherokee
What should the pressures on the low and high side of the air conditioner read ?
low side should be about 30 psi at idle speed, high side 120 to 180 psi depending on ambient temp. higher temp, = higher pressure, as you increase engine rpm to say 1000 low side should drop to 10 to 15 psi & high side should increase about 30 psi. If high side goes over 280- 300psi you have contamination (air) in system or over charged with refrigerant. you will need to recover freon, evacuate & recharge system with proper amount of refrigerant. If the low side drops below 0psi or into vacuum then the refrigerant level is low, you will have to check for leaks , repair leaks & refill refrigerant.
Hope this helps
Paul T
Jun 01, 2011 | 1997 Chevrolet Suburban
Hello, the problem is varies high and low pressure
try idle screw adjust so motor dosnt labour
Mar 26, 2010 | Karcher Garden
Output pressure varies high low
Bleed the system by running water without the unit on, You have an air lock, open the drain cocks and allow water to run slowly for 2 minutes, then close everything and try it
Mar 05, 2010 | Karcher 2500 PSI Pressure Washer
What are the settings for R22 on an older 2 ton unit? Right now it is 140 on the high and 60 on the low. Tag on air unit says 150 low 300 high (PSI). I don't to add or remove freon.
Sustion or low pressure depending on indoor temp about 70-75 head pressure will vary with a,bient temp. But no moe than 260 to 275. Rus
Jul 15, 2009 | Whirlwind FH-778 Air Conditioner
Engine on idle runs high and low, high and low...
Had same problem. Turned out that antifreeze was low causing insufficient water pressure. Could also be a bad sensor. I would check both.
Dec 29, 2008 | 1993 Honda Prelude
Honda Karcher G2400HH-R Pressure Washer Logo
164 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
