Video Cameras Logo
Question about Panasonic Video Cameras
My SD D card from my Panasonic camcorder does not work in my TV
Posted by stan a beller on
Jay Plesset
  • Panasonic Master
  • 2,942 Answers
Some TVs can only show still pictures from a memory card...
Posted on May 10, 2015
1helpful
Can I use a 8gig SDHC card in my panasonic nv-ds65 ?
The NV-DS65 uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in this camcorder. You need to use SD cards 2GB and smaller.
tip
MOD Files on Mac OS, How to Play Camcorder MOD Files on Mac
Similar to TOD, MOD is a kind of recording format being used in digital tapeless camcorder like JVC, Panasonic, Canon. MOD video format is comparable to XDCAM EX, HDV and AVCHD.
MOD is used exclusively for standard definition video files, while TOD is used for high definition files. Both MOD and TOD are file-based formats that are stored on a random-access media. Directory structure and naming convention are identical except for extensions of media files. Standard definition video is stored in MPEG program stream container files with MOD extension; in most other systems these files have extension MPG or MPEG.
The following list is about JVC, Panasonic, and Canon MOD camcorders.
JVC MOD camcorders
* 2004: GZ-MC100 (SD), GZ-MC200 (SD)
* 2005: GZ-MG30 (HDD), GZ-MG70 (HDD)
* 2006: GZ-MG37 (HDD), GZ-MG77 (HDD), GZ-MG505 (HDD, SD/SDHC card)
* 2007: GZ-MG130 (HDD), GZ-MG155 (HDD), GZ-MG255 (HDD), GZ-MG555 (HDD, SD/SDHC card)
* 2008: GZ-MS100U (SD/SDHC card)
* 2008: GZ-MG7230 (30 GB HDD, MicroSD)
* 2009: GZ-MG630 (60 GB HDD, MicroSD), GZ-MG670 (80 GB HDD, MicroSD), GZ-MG680 (120 GB HDD, MicroSD)
Panasonic MOD camcorders
* 2003: SV-AV100 (SD card)
* 2005: SDR-S100 (SD card)
* 2006: SDR-S150 (SD/SDHC card)
* 2007: SDR-S10 (SD/SDHC card), SDR-H18 (HDD, SD card), SDR-H200 (HDD, SD/SDHC card)
* 2008: SDR-H20 (HDD, SD/SDHC card), SDR-H60 (HDD, SD/SDHC card)
* 2008: SDR-S7 (SD/SDHC card)
* 2008: SDR-SW20 (SD/SDHC card)
* 2009: SDR-SW21 (SD/SDHC card)
* 2009: SDR-S26 (SD/SDHC card)
Canon MOD Camcorders
* 2008: FS100 (SDHC), FS10 (SDHC), FS11 (SDHC)
* 2009: FS200 (SDHC), FS21 (SDHC), FS22 (SDHC)
For Mac users, when they want to watch MOD files shot by JVC, Panasonic, Canon camcorder with iPad, iPhones, iPods, in Quicktime, in iMovie, in iTunes, or on PCs, etc. They may be annoyed that how to upload MOD files to Mac and play MOD video on Mac OS.
Now, there are tutorial and guide for you below will help you solve these problems.
1. Connect your JVC, Panansonic, or Canon camcorder to your Macs or PCs with cable USB or Wifi.
2. Turn on your camera and select the mode of camcorder like PC mode. iMovie on Mac will open automatically the Import Window.
3. You can review your video or select "Import All"and select your JVC, Panasonic, or Canon camcorder on the computer screen and click "OK."
4. All camcorder MOD videos will have the file extension "MOD" Once the backup is complete, then close the program.
After uploading your camcorder MOD files to your PC or Mac, you can use
a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Sep 13, 2010 • Computers & Internet
tip
How to Upload/Put and Play JVC, Panasonic, Canon Camcorder MOD Files on Mac
JVC MOD camcorders
After uploading your camcorder MOD files to your PC or Mac, you can use a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Aug 12, 2010 • Computers & Internet
1helpful
My viera tv will not play any movies! I have converted movies to both mpeg2 and avchd formats, put them on my sd card, and the tv will not play them!
Panasonic requires a very strict AVCHD structure from a camcorder that nobody has been able to figure out yet.
http://www.dvinfo.net/forum/avchd-format-discussion/99716-avchd-play-panasonic-sd-card-slot.html
Seems like the Viera is fussy about video encoding.
My lexar sd 4G card won't work in my camera? says card error in card record mode?
The PV-GS36 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot it will not work properly. You need to use SD cards, 2GB and smaller.
Panasonic SV-AV10 SD memory card max size
Hi the Panasonic camcorder supports a memory card up to 2GB. So in answer to your question, yes it can.
Hope this helps
Muzzi_123
Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
Panasonic SD Card reading problem
Yes. The device was not using a standard file system. There usually is no cure. Try this. Format the card in the device and try one more time. Many don't know to perform this step.
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
