Question about FUJIFILM Cameras
My fujifilm fine pix s5000 digital camera is having some problems. When I turn it on the screen is white but I can see icons. I'm not sure if it's related to the camera or if I just need a new card?
Posted by Valerie Hart on
Karl Whisenand
    Genius:
  • 1,554 Answers
The video from the ccd is not making it to the lcd
does it shoot pictures if so then you have a good point n shoot blind camera
its not worth fixing .
Posted on May 10, 2015
5 Related Answers
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: Fuji Fine Pix s5000-Horizontal lines with purple coloring mixed
not a software issue it is
CCD FAILURE !
CALL Fujifilm they will do it FREE it is a known problem in thousands of camera i got my S5000 with same problem repaired FREE from FUJI just call them
BAD CCD
RATE ME WELL !
Posted on May 31, 2009
Anonymous
SOURCE: fine pix fuji S5000
i called fuji they told me that the ccd in my camera is under lifetime time warranty so i sent my camera in and they fix it free of charge goodluck
Posted on Oct 03, 2008
Anonymous
SOURCE: Fuji S5000 Digital Camera--White EVF/LCD Screen
i was told by fuji it is the ccd or cmos sensor effectively the eye of the camera it is faulty and needs replacement fuji said it would cost £90 to replace as the newer model of the fuji is only 145 i opted to buy a new camera so i bought i differant brand and am very happy with my dmc tz3
Posted on May 29, 2008
Ty Price
  • 11967 Answers
SOURCE: Hello my barely used fujifilm fine pix J38 camera zoom error mess
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
Steven Monser
  • 275 Answers
SOURCE: FUJIFILM FINEPIX S5000.No image on viewfinder or LCD.
I think there is a small button on the back of the camera near the bottom that turns the viewfinder off and on I think. It should be in the manual.
It might have gotten bumped while in the bag.
Posted on May 24, 2010
MY finepix s5000 fujifilm camera has a white screen displaying when i turn it on, is there anyways i can fix that problem with out haveing to take it in.
Had the same problem with my s5700, white screen, took it apart. two screws on the left (facing the screen) under the strap, two in the usb compartment, two (screen side) screws on the bottom, three screw in the battery compartment, and the final just below the right side strap. Carefully pull the back off and check the ribbon connection from the lcd to the board. push it in made sure its seated. Reasemble being careful not to bend the ribbon connectors. Worked for me.
Aug 05, 2010 | Fuji FinePix S5000 Digital Camera
Having purchased a new computer I cannot dowload the disc to install fujifine pix on my machine,
not sure if u want the software or the driver , but you could try here.
http://fujifilm.co.uk/consumer/digital/digital-accessories/software-manuals
Jan 13, 2010 | Fuji FinePix S5000 Digital Camera
Fujipix S5000 screen is all white
I just started having the same problem with my S5000, also.
Jul 11, 2009 | Fuji FinePix S5700 Digital Camera
CCD FAILURE !
BAD CCD
RATE ME WELL !
May 27, 2009 | Fuji FinePix S5000 Digital Camera
CCD FAILURE
CALL FUJI for FREE repairs u are eligible i got mine repaired free it is a known problem
Regards
Zohail
May 25, 2009 | Fuji FinePix S5000 Digital Camera
HI All of a sudden, there is lets say no more image on the display or the image is purple and full of weird lines. No image at all and when I click to take a picture everything works out well: the flash...
BUT NOW U HAVE FOUND SOLUTION
CCD FAILURE !
but u will get it repaired Free of Charge as Fuji has taken notice as all manufac and i got my S5000 repaired Free from Fuji just call them tell them about BAD CCD it is a known manufac fault in thousands of cameras just call them quick
www.fujifilm.com
see this thousands suffer from this
http://www.imaging-resource.com/badccds.html
May 08, 2009 | Fuji FinePix S5000 Digital Camera
I have a fujifilm finepix S5000 when camera is turned on it just shows a white screen. Cant take pictures, movies, nuffin works. Can u help, please.
if u see white screen and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
Apr 09, 2009 | Fuji FinePix S5100 Digital Camera
Software
This may be what you need:
http://www.fujifilm.com/products/digital/download/02/ist.html
Either way, that's the FujiFilm website, so it should be somewhere. All I found was updates for different versions (i admit i didn't spend too much time looking).
www.fujifilm.com is the original website, so I recommend you go the go, select country, select camera, etc instead of typing in the link above (it will probably be dead.....it always happens).
Jun 19, 2008 | Fuji FinePix S5000 Digital Camera
Cameras Logo
237 people viewed this question
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
