Question about Schneider Xantrex C12 Lighting Charge Controller, 12 V DC
Where do i hook the ground wire to - Schneider Xantrex C12 Lighting Charge Controller, 12 V DC
Posted by brian on
Marco De La Fuente Fernandini
    Habit-Forming:
    New Friend:
  • 159 Answers
You have to connect it to a good ground connection,under the ground and at a copper bare rod under ground(At least 2.40 Meters long
Posted on Nov 10, 2016
Have cub cadet rzt 50 ground wire pulled loose
green wire is a ground for the wire harness and needs to be grounded with the ground cable and it usually grounds to an engine mounting bolt or close to it
Oct 19, 2014 | Garden
Ok so I have a 1978 chevy pickup, and the fuel gauge isnt working. It says i have a full tank all the time. Got any ideas on how to fix it? Also my left tail light isnt working, and the bulbs are all good,...
Check the ground wire to the fuel sending unit @ the tank, A ground wire can be spliced in and located on a good metal surface just about any where..
Aug 15, 2011 | 1978 Chevrolet C1500
I have 2000 mazda protege and i tried hooking up my stereo and the ground wire is disconnected where is it at so i can hook it bacc up
a ground is a ground . take a small braided copper band attacch it to the chasis of the stereo and the other end to the car
Jul 25, 2009 | Mazda Protege Cars & Trucks
Difficulty wiring into GM harness
well if your trying to actively wire it up with the car battery still connected that is why you are blowing fuses. just a heads up too if you have a live connection while hooking up the cd player you could short out other electrical devices and you could be in alot more trouble thatn just blowing fuses. the black wire is what is blowing fuses its because you have it hooked up wrong to a wire that is sending voltage not recieving voltage. ground the black wire to the actual chassis instead of hooking it to the ground wire from the harness or whatever color its grounded to which shouldnt be anything but black if you have the black wire hooked up to ANYTHING that isnt black that is why you are popping fuses. so hook up the red yellow and make your own ground you shouldnt have any problems after that.
May 08, 2009 | Car Audio & Video
Hooking up trailer lights
Are you checking your lighting with the trailer hooked up? This is the trailer's ground source. The white wire on both sides of the plug is the ground wire. Grounds are very important, Make sure they good and clean.
Jun 13, 2008 | 2001 Ford F150 Styleside SuperCrew
Rebuilt heads on 96 blazer 4.3 now no power
Check your neutral switch, its usually on drivers side on the back of stearing column .Its easy to reach and if you consult a mechanics service book, it will be alot easier to find and save you alot of frustration. Please rate this. Thanx.
Jun 05, 2008 | 1996 Chevrolet Blazer
Car cd player installation
Noooo, lol they should all have a seperate location, look at a wiring diagram from your factory speaker harness, or buy an adapter from scosche or something (available at wal-mart for like 7 bucks) to standardize them. And your speaker wire should not be hooked up to the ground EVER.
Black - Ground
Red - 12V
Yellow - Battery
The red and yellow may OCCASIONALLY be required to be at the same place, but i've only had to do this with a vehicle from the 60's.
Jun 03, 2008 | JVC KD-G310 CD Player
Mine is actually a q4000 4 channel amp
First of all, you MUST HOOK UP YOUR GROUND WIRE FIRST. You may have damaged it if you hooked your power and trigger wire first and then the ground wire. Unhook EVERYTHING except the hot wire, ground wire and trigger wire. If you still can't get the unit to come on then it is time for a trip to the repair shop. Good luck.
Feb 01, 2007 | Cadence Q200 2 CHANNEL POWER AMPLIFIER...
Schneider Xantrex C12 Lighting Charge Controller, 12 V DC Logo
901 people viewed this question
Top Schneider Renewable Energy Experts
Greg Scott
Greg Scott
Lukas Alexander
Level 1 Expert
Are you a Schneider Renewable Energy Expert? Answer questions, earn points and help others
