Question about Ovens
I was trying to turn on the oven and pressed different buttons now the timer is flashing but I can't get the oven to turn on. I've tried turning the power off at the wall but that doesn't work. Help!
When I have tried powering it off I've also got info coming up and then it goes back to the clock which keeps flashing, not matter what buttons I press the oven won't turn on.
Posted by Mick Daly on
kingsley
    Habit-Forming:
    New Friend:
  • 20 Answers
Holding the clear button for 3 seconds activated the latch to move to the unlocked position and doing this we be able to close the door,
pull the latch back to the unlocked position. turned the power back on and the oven we be working fine .
Posted on May 09, 2015
jimmy jinx
    Master:
  • 456 Answers
Turn the cooker off and leave it for a while ( mabe 30 mins or so ) it wont reset the clock after a quick on/off
I can't get the oven to work and the timer is flashing on 0.00
Have you turned the timer off? Usually involves pressing a combination of buttons at the same time. If this doesn't work try turning off at the fuse. Wait a min and turn back on.
Jan 13, 2016 | Ovens
After a power outage, the oven control light keeps flashing.
You have too reset clock pressing two buttons works for me
Nov 09, 2015 | Ovens
Stoves 720G Manual
SOMEONE POSTED
However...I discovered the little buttons on the timer come out completely. So I used a cocktail stick to poke about inside the holes where the buttons go till the Auto mode light disappeared and the cooker went back to manual. And my oven works again as before.
Jan 04, 2015 | Stoves Ovens
Thermador oven preheat light will come back on during cooking session. The clock has also stopped working.
There may be a fault with the control board.
http://appliancejunk.com/forums/index.php?action=dlattach;topic=9146.0;attach=5091
Oct 05, 2014 | Thermador Ovens
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
Teka ha 830 oven timer will not reset after power cut
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Jan 29, 2013 | Ovens
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
Jun 28, 2011 | Stoves 720EF Electric Double Oven
We cannot turn the oven on! No instruction manual. The 'A' is flashing on the 'clock'/timer - what does this mean?
This means it is in auto mode. It must be in manual mode for the oven to work. Turn the oven to ON. Some clocks have 2 or 3 buttons. Press the buttons at the same time/try all different combinations. This might take a few minutes, be patient. When the oven indicator lights the clock is in manual mode.
Apr 01, 2011 | Ovens
How do i turn on a white atlas ceramic electronic oven, the ceramic top is working,but the oven screen flashes from"0:00" to "auto" when i try and fiddle round with the oven...
Turn the oven control on. Now play with the buttons on the electronic timer/clock. Try all different combinations. Trying pressing them at the same time. This may take 5 minutes or more. If the timer is not faulty this will work, be patient. When the oven indicator light comes on the oven is on and the timer is now in manual mode.
Feb 25, 2011 | Ovens
Bottom oven not working, nothing comes on at all, though the display is flashing AUTO, and cannot change this as do not have manual. Thanks
It sounds like the oven is not working as the electronic timer is in auto. mode. It must be in maunal mode for manual oven operation. Turn the oven on. Muck around with the buttons on the timer and try all different combinations. This may take 5 minutes or more. When you do hit the manual mode the oven indicator light will come on and the oven will work.
Feb 15, 2011 | Ovens
Ovens Logo
240 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
