My dad was trying to turn the oven on this morning, he pressed different buttons. Now the oven won't come on. The time display is just flashing or if we turn it off at the wall sometimes info comes up on the display. Any ideas???
Power to the unit by removing one or more fuses or tripping one or more breakers at the main entrance panel or at a separate panel. If the range is fused at a separate panel, this panel may be located adjacent to the main panel or in a basement, crawl space, or other location. If there is a grounding wire to the range, disconnect it. Make sure the power to the unit is off.
Servicing FusesIf the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly.
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.
If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
