Question about Samsung Heating & Cooling
I have samsung split inverter airconditioner if i turn it on the out door unit wont work
Posted by Ruel Depalobos on
johnny rebel
    Top Expert:
  • Samsung Master
  • 10,875 Answers
Get it serviced
Posted on May 09, 2015
5 Related Answers
Anonymous
  • 143 Answers
SOURCE: My split system airconditioner made
Something has exploded. Look inside to see what it was.
Posted on Jul 24, 2008
Anonymous
  • 158 Answers
SOURCE: Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
Posted on May 28, 2009
Anonymous
  • 81 Answers
SOURCE: my samsung split type airconditioner is shutting down.
This is an outdoor unit error. I would have the system serviced.
Mat
Posted on Jul 16, 2009
Anonymous
SOURCE: Air conditioner stop working after fall and lack
buy a f u c k i n g new one ya cheap c u n t
Posted on Oct 11, 2009
Anonymous
  • 81 Answers
SOURCE: Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
What does malfunction code E6 mean in a koppel super inverter airconditioner
WHAT IS THE MEANING OF E4 code in koppel inverter split type
May 01, 2012 | Heating & Cooling
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
I have just purchased and installed a Samsung AQ12FEN. A qualified Airconditioner company installed the unit. The slpit unit installation is a back to back configuration It replaced a 8 year old split...
This could be caused by an installation problem. The system could be severly overcharged, causing the compressor to load up and can cause a failure. i would start there. Is your intaller qualified to install these systems? (does he know what he is doing?)
I recommend, checking the refrigerant pressures first. You can also check the Polarity of the high voltage in to the outdoor unit. If the compressor is an Inverter Drive compressor, and the polarity is reversed, the compressor can run backwards causing the noise and eventual failure. To correct a polarity problem, simply remove the 2 high voltage wires that feed power to the outdoor unit from the board or contactor. Then reconnect those 2 wires, in the opposite position. (say you take loose from the unit and the Black wire is on the right side, and the white wire is on the left side. Simply swap sides, reconnect the Black wire on the left side, and the White wire on the right side.
Hope this helps,
Brian
Dec 15, 2010 | Samsung Heating & Cooling
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
We have an LG SQ/SR/ST chassis inverter model air conditioner....the airconditioner keeps stopping with the screen display...C6 appearing. When we turn it off at the mains it seems to reboot it for a while...
i can figure out what model a/c you have from this discription/ is this a lg floor mod. or window model or lg duckless split system
one comon problem causing faut is dirty filter or condensor but hard to figure if i cant place the unit disciption.
Oct 20, 2008 | LG Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
