Question about Coby Televison & Video
Coby dvd-514 reads wrong disc - Coby Televison & Video
Posted by Wade Johnson on
johnny rebel
    Top Expert:
  • Coby Master
  • 10,875 Answers
Coby DVD 514 Instruction Manual Page 24
use a dvd player cleaning disc,,make sure the disc is supported,it is NOT a blu ray player,only a dvd player,make sure the discs are clean and not scratched
Posted on May 09, 2015
5 Related Answers
Anonymous
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
Komal Brar
  • 4 Answers
SOURCE: Dvd reads wrong disc
Since 4 days I've searched 99% of internet to fix 'Wrong Disk' solution for my DVDV822-05 Player, but I could not get any such solution. Some solutions for other players of the same company is to change region codes but I could not find these codes for this particular model. I got this player from some other country which I dont know. It's sayying 'Wrong Disk' to all disks either MP3, audio, VCD, DVD etc. It's my humble request to all e-guys and companies to find some solution for this model.
Posted on Jan 22, 2008
Anonymous
  • 17 Answers
SOURCE: my coby portable dvd player keeps saying wrong disc
You may need to clean the laser in the unit. You can purchase a cleaning disk at Radio Shack or Best Buy. They are normally less than $20.
Posted on Nov 06, 2008
Anonymous
  • 563 Answers
SOURCE: wrong disc error
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if the player will no longer read any commercial dvd that you attempt to play, the unit is defective and needs to be replaced. The unit has a 90 day warranty from the date of purchase. You will need the receipt in order to receive a warranty exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
Anonymous
  • 89 Answers
SOURCE: Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Posted on Jul 28, 2009
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Our dvd player is saying wrong disc all of a sudden.
IT could be 2 things : check the region of dvd , or clean the OPTICAL LENS directly with a dry Q tip gently , if it still reads " wrong disc" then replace the optical lens , AJ
Jul 09, 2009 | Coby DVD-514 DVD Player
Coby DVD screen setting wrong
check on the cover of the player the info to reset should be there
Oct 26, 2008 | Coby DVD-514 DVD Player
"another wrong disc"
I too do not understand how to check the motor or change the wire
Jun 29, 2008 | Coby TF-DVD7100 Portable DVD Player
My DVD Player Coby 514 Only Show Load disc
Checa si el laser envia buena luz,limpia el lente del laser puede que este sucio con un cotonete impregnado en alcohol limpialo despues le secas.
Jun 21, 2008 | Coby DVD-514 DVD Player
Coby dvd 514 remote
BAD NEWS.....I READ THIS FROM THE COBY PRODUCTS WEBSITE: COBYUSA.COM..... What is the code to program my Universal remote with my Coby DVD player? There is no code to program our DVD players with your Universal remote, you need to use the remote that came with the player.
Aug 27, 2007 | Coby DVD-514 DVD Player
Region
coby 514.
power up. put disc in tray
press set up
then vol+ vol- vol+ vol-
code appears in top right 1
change altering left and right buttons
leave on 255 multi region (all discs)
press set up.
Coby DVD-514M
Turn unit on with remote
NO DVD in the tray (mine was closed, but opened might work)
Press TITLE then 1 then 9
Gray box will appear in the center of the screen with number 1 in the middle
Using up/down arrows change to desired region (0 for REGION FREE)
Jun 12, 2007 | Coby DVD-514 DVD Player
WRONG DISC
Aug 02, 2006 | Coby DVD-224 DVD Player
Televison & Video Logo
Top Coby Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
