Question about Maytag Washing Machines
What is fault 27 maytag washer - Maytag Washing Machines
Posted by Guy Takahashi on
John Ireland
  • Maytag Master
  • 2,355 Answers
F27 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is clearedFirst, UNPLUG the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, proceed to step 2.
2. Check the drain hose and make sure it is not plugged or kinked.
3. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
4. Check/Clean Drain Pump Filter of foreign objects.
5. Check for Drain Pump Failure.
6. Check the Inlet Valve for proper shut off
7. Check the Pressure switch for proper operation.
Posted on May 10, 2015
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
What size washing machine is this
Your Maytag Neptune MAH6500A Front Load Washer has dimensions:
Width : 27"
Depth : 29"
Height : 42 1/2"
Capacity : 3.34 cu. ft.
http://www.ajmadison.com/cgi-bin/ajmadison/MAH6500AWW.html
May 22, 2014 | Maytag Neptune MAH6500A Front Load Washer
Complete list maytag error codes
This was taken from the MAH8700A 27" washer service manual, I'll look for the 8700 if I have one, since Samsung made both of these models, I think the failure codes are the same. Pleazer Appliance...
Apr 14, 2014 | Maytag Neptune MAH9700 Front Load Washer
Washer frequently stops cycling at 14 and 27 minutes remaining
I have the same exact problem... can't believe it's just me. I too would love to know what's wrong with this machine! Is their a recall for this???
Sep 04, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
157 people viewed this question
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
