Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
LG Fridge door constantly beeping when closed
My fridge is only a little over 1 yr old, and has displayed intermittent problems with either the freezer or the fridge doors beeping when the doors are closed properly.
This has now escalated to the freezer door CONSTANTLY beeping when properly closed, and it's driving us batty!
Is there anything we can do to make it stop - please????
Posted by musicmad534 on
Anonymous
    Champion:
  • 363 Answers
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Refrigerator temperature can't be set to cold - sensor light shows 9C and keeps on beeping. Samsung model RB1855SL
I had this exact problem with my 4 yr old Samsung RB1855SL refrigerator. BTW, the temperature display doesn’t display higher than 9C, even when its warmer inside. The fan wasn’t turning on to circulate the cold air, although the cooling coils were still cooling. There was no excess ice build-up. The freezer was working fine.
I thought perhaps the fan was toast or the temperature sensor. Then I noticed the interior fridge light was not turning off when closing the door (but the freezer light was). BINGO—thig light switch was the problem. A small piece on the inside of the fridge side of the switch was broken. When the door was closed, the broken switch didn’t let the fridge know that the door was in fact closed, causing the door alarm to keep beeping. This must shut the fan down in order to save energy when regularly opening the door.
DIY fix: I removed the switch (until I could get a replacement) which is located to the left of the lower door hinge (right hand side). Gently, with a flat nose screw driver, I pried it out.
The light no longer turned on when opening either door but that was a small price to pay compared to the incessant beeping and rotten food. The part can’t be very expensive and I can replace it myself. The local appliance repair shop will order it for me.
No expensive “internal brain” needed to be replaced or an expensive repairman needed to be called. Good luck!
Aug 17, 2008 | Samsung Heating & Cooling
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Kitchenaid KSCS25INSS
im not sure about the alarm but im going to assume its a door ajar alarm tilt the fridge back using the adjusters on the front wheels till you can open the doors about 1/4 let them go and it will close its self fridges are air tight and some times when you shut one door the air it pushes will slightly open the other the installation inst say level the unit but its better to have them leaned back the lights probably turn of auto if a door is ajar give that a try and let me know please
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
Intermittent Beep
check door switch is operating and the light switches off. an easy way is to prize back the seal a bit with door closed and if light is still on you can see it
Jun 21, 2007 | Zanussi ZX97 / 5 Bottom Freezer...
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
4,424 people viewed this question
Top LG Refrigerators Experts
Michael Thomas
Michael Thomas
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
