Bought eBay - China manufacture - got Hebrew manual
SOURCE: Mag Innovision LT576s won't power up
Clearly your monitors are evil. Try turning them on at home and see how you fair out. :)
Cheers,
Mike
SOURCE: need driver and users manual for mag innovision lt576c monitor
Download updated drivers and manual from Mag website link here: http://www.maginnovision.com/Support/Downloads.aspx where you select product group, type and model.
SOURCE: need a driver and users manual for mag innovisionLT576s
ViewSonic (HASU05F)
Information:
Product details
Price Range:
$25.00 - $40.00 at 3 stores
This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer
ATI – http://www.atitech.com/
Nvidia - http://www.nvidia.com/
Matrox – http://www.matrox.com/
Pinnacle – http://www.tridentmicro.com/
Trident - http://www.tridentmicro.com/
Diamond Multimedia – http://www.diamondmm.com/
Cirrus Logic - http://www.cirrus.com/en/
http://www.opendrivers.com/driver/214283/mag-lcd-monitor-drivers-windows-95-98-2000-xp-me-nt-free-download.html
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor.
Answer
There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
SOURCE: i need driver monitor mag innovision for install
Chek Ur OS and download drivers from here :
http://list.driverguide.com/list/company621/
SOURCE: I bought a mag innovision model 780 monitor at a
With Most Mag monitors, the plug is a simple 3 prong on the bottom side of the monitor. Though it isn't proprietary, it isn't a common power plug either. Radio Shack does carry this type of cord. Just look on the bottom side of the monitor itself. the three round plug "thingy" is where the 110v plugs in straight from the wall. Best of Luck!
