I need help finding out why the light on my monitor is flashing orange & green. The monitor is not turning on at all when computer boots up or when you press the power button on the monitor itself.
What could this be??? Thank You!
Common problem with Dell Monitors. There are two components inside a LCD monitor, a video board and a power supply board. One of them is bad. Since you have the flashing LED, i would guess it is the video board. You can buy these boards all over the internet since Dell monitors are constantly defective.
Unless you recently installed new video or monitor drivers, it sounds like either bad cabling to your computer (check the cables?) or the ribbon cable inside the LCD monitor has come unseated.
The unseated ribbon cable problem is more common if you recently moved the monitor or dropped it a bit. You can open the back of the LCD monitor (unplug it first of course) and check to make sure the signal ribbon is seated properly, this is a common problem.
Good luck...
SOURCE: now, when I boot up,
It has shorted out transistors in the inverter circuits, also kook for bad caps with domed tops. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Replacement board: http://www.lcdrepair.us
http://s807.photobucket.com/albums/yy352/budm/DELL/
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Checked cords.
Power light on power pack is green.
Hooked it up to another computer, same thing.
Unplugged cables from back and replugged.
Blew canned air in to blow away any dust.
Threw it in the street, ran over it with the car several times, hit it with a sledge hammer. Told it I was sorry.
This is a Microtek 712S
The power button just flashes blue, lavander, orange. Nothing on screen.
I'm bummed.
Microtek website is no help at all.
gateway monitor wont come on
