Question about Fitbit Flex Wireless Activity & Sleep Wristband, Slate
My battery is charged but showing empty on computer. I restarted it but still showing empty.
Posted by Lorraine Dougherty on
Rich Laue
    New Friend:
  • 26 Answers
The reason nothing shows on the Dashboard is because your tracker hasn't synced. If there is no communication Fitbit won't know what your tracker is up too.
Check this link:
http://help.fitbit.com/articles/en_US/Help_article/I-m-having-trouble-syncing-my-tracker-to-my-dashboard
I'm not sure what device you have but the Zio is the only unit with a battery that can be taken out.
The others you might want to clean the charging contacts, turn off then on the Bluetooth., restart the Fitbit, restart the phone, remove the Fitbit from the BT settings on the phone or computer, restart phone/PC, add the Fitbit as a replacement device. My him
Posted on Dec 02, 2015
Leslie Odierno
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
With computer turned off take out battery and wipe off contacts then reinstall battery. If it is still empty after letting it sit a bit to see if it is charging you either have a bad battery or the charger in the computer is bad . that is an expensive fix. usually not worth the money unless you have an expensive computer and then that probably would not happen.
Posted on May 07, 2015
Nikon D80 showing empty battery
Are you using the same charger for all of the batteries? If so, you might want to try another charger. I had a charger for my batteries (I have a D7000) that turned out to be bad. It would show it charging and then having charged them, but they were still dead.
If that's not the case, check the contacts inside the camera, that they are clean and free of debris. Those little gold contacts needs to match up nice and solidly.
If it's still a no-go, call 1-800-NIKON US (1-800-645-6687) 9AM-8PM EST, Monday through Friday.
Mar 16, 2014 | Nikon D Cameras
My nokia 2330c-2 is always low on battery even after I have charged it and it most at times hangs and goes off automatically
nokia 2330c calling time battery empty & when restart phone battery full plz provide me this problem's solution ....
Apr 20, 2011 | Nokia Classic 2330 Cell Phone
Need charging instructions
Charging device: Plug the device into computer. You can unplug the device any time you want without problem with device
If your device's battery has empty, you need 3 hrs to charge to full.
If you want to check battery level during devive plug into pc: (set up MTP or Auto mode) open My Computer, right click on icon of the device, select Properties, it shows you batteries level
Feb 02, 2010 | SanDisk Sansa Clip MP3 Player
My iphone does not want to start up PLEASE HELP!!
sounds like you either need a new powerpack or a new battery :( sorry
Jun 24, 2009 | Apple iPhone (16 GB) Smartphone
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Hi, I have a Nikon D300. First problem - The battery started showing empty / full / then empty again. Bought a new battery, worked first time, then the same problem empty / full / empty. Change the...
A capaciter in your camera is not working properly and is discharging your battery even when the camera is turned off (this is a cheap problem to fix but must be sent back to NIkon for repair
Dec 06, 2008 | Cameras
Phone regularly cutting out
This is due to malfunction of battery,
i have also experienced same kind of problem with nokia set which is other model. i have also done same what you have done. Change or replace your mobile battery. so it 'll finally solves your problem.
Apr 21, 2008 | Nokia 2310 Cellular Phone
Won't charge
I'm having this problem also. I have had it "charging" for at least 12 hours, and the screen still shows the battery filling up.
Dec 08, 2007 | Philips GOGEAR SA6045 MP3 Player
Fitbit Flex Wireless Activity & Sleep Wristband, Slate Logo
704 people viewed this question
Top Fitbit Exercise & Fitness Experts
ray gallant
Joseph Coppeto
Joseph Coppeto
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
