Question about Umax Astra Office Equipment & Supplies
Have a astra h 1.6 on an 07 plate, have done the headgasket,but the light was on be for that ,now the code is p0011& sumtime poo14 comes up all tho car is running fine ??? jim
Posted by jim sohal on
5 Related Answers
Anonymous
SOURCE: trouble codes p0011 and p0021
IT HAPPENED THAT SOMEBODY CHANGED THE CLUTCH AND THE FLYWHEEL AND INSTALLED THE WRONG FLYWHEEL AFTER WE INSTALLED A NEW FLYWHEEL THE PROBLEM WAS GONE.BUT THANKS ANYWAY.
ATT.:RAMON JIMENEZ
Posted on Oct 12, 2008
Anonymous
  • 350 Answers
SOURCE: CAR
hi sounds like a faulty hydraulic tappet what miles has it done and check your oil level as the camshaft will be last thing to get oil if everything appears to be ok service the engine yates210456
Posted on Oct 19, 2008
SOURCE: I have a P0011 "Camshaft Position/Bank 1 code.
OK check the CMP sensor connector for cleanliness, sometimes oil can get in and disrupt the signal transmission to the ECU. Check the wire loom continuity all the way back from the CMP to the ECU. If the error code persists remove the cam sensor, clean its tip of any debris and refit.
Posted on Nov 11, 2010
Testimonial: "Thanks joe2mercs...you had the problem diagnosed correctly. Cleaned and light has not come back on. U saved me a lot of $."
Danniboi
Dan Doherty
  • 1098 Answers
SOURCE: i have a 2002 gmc
Hi
that code is cam sensor for the first question, the second one your daughters car sounds like either a battery earth problem or a alarm / immobiliser issue. quite common on that model, the dealer will know more worth giving them a ring for some advice before going any further with your daughters car.
Also your car have both the cam and crank sensor checked, crank sensor is normally p0017 but I have heard that p0014 code can be either.
Hope that helps
Regards
Dan
Posted on Dec 29, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: volkswagen passat wagon 2004 codes p0300 p0302 p0304 p0011 runs fine
You have random misfire codes as well as misfires detected on cylinders #2 and #4. P0011 is likely the root cause of the misfire being detected
P0011 VOLKSWAGEN - 'A' Camshaft Position Timing Over-Advanced Or System Performance problems.
Possible causes- Dirty engine oil
- Low engine oil level
- Camshaft actuator circuit open or shorted
- Camshaft actuator circuit poor electrical connection
- Faulty camshaft actuator
There may be a factory bulletin on this code, check with the VW dealer on that. Possible defective Camshaft actuator.
Posted on Oct 08, 2012
Code p0011
http://www.datsc.com/tabid/122/OBD-Error-Code/P0011/Diagnostics/Mercedes-Benz/Default.aspx
"..........OBD Code P0011refers to
A code P0011 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0011 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is above a set limit (over-advanced), the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
SymptomsPossible sumptoms of OBD code P0011
Most likely a P0011 DTC will result in one of the following: hard starting, poor idle, and/or stalling. There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
CausesPossible causes of OBD code P0011
A P0011 DTC trouble code may be caused by one or more of the following: Incorrect camshaft timing Wiring problems (harness/wiring) in intake timing control valve control solenoid system Continuous oil flow to VCT piston chamber Failed timing valve control solenoid (stuck open)
Possible SolutionsThis DTC code is a result of a mechanical fault of the VCT unit or related components, so there is no need for electrical diagnosis. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
Related CodesP0010 P0012 P0020 P0021 P0022..........."
Oct 04, 2013 | Mercedes-Benz Cars & Trucks
P0011 code
The P0011 means "A" Camshaft Position - Timing Over-Advanced or System Performance.
__________________
mini vci for tis
Aug 29, 2012 | 2006 Chevrolet Monte Carlo
Code po606 is coming up on my 2004 trail blazer
P0606 is an indication that the engine computer (PCM) has an internal fault, it may require reflashing.
P0014 is Camshaft position timing-over advanced, this could be a result of the PCM problem.
Jul 29, 2012 | 2004 Chevrolet TrailBlazer
Code p0011 bank 1 intake timing position is over advance,oil light flashes/comes on when i take off/slow down or at complete stops
The computer controls the cam timing by using a solenoid valve inside the engine. The valve works by oil pressure.
The code means the computer can not control the valve timing. Usually the valve is faulty or there is a problem with oil pressure.
Since you say the oil pressure light is coming on, I would expect to find a problem with the oil pump or excessive dirt in the engine.
If the oil pressure switch is good, it will turn the light on when the oil pressure drops below 5 psi. And if it is that low, I doubt oil is reaching the valves.
Jul 20, 2012 | 2002 Nissan Maxima
P0011 Emgine code on 2007 Kia Optima
Have you had a timeing belt done? The code refers to the VVT (Variable Valve Timeing) or VCT (Variable Cam Timeing) Same thing. It may need a cam sensor replaced or a problem with the VVT control solinoid This can happen if the VVT solinoid has been unbolted for some reason. The computer of the car may just need to be re set if your lucky
Jun 27, 2012 | Kia Optima Cars & Trucks
2004 trailblazer has a code of poo14
The code is a code that has had a lot of controversy in this subject. I have provided a link to another site that will explain in depth on what the code is and what is needed to be done to get the job done correctly.
http://forums.trailvoy.com/showthread.php?t=28340&highlight=Camshaft+actuator
Jun 24, 2011 | 2004 Chevrolet TrailBlazer
My check engine light appears sumtimes on my dash board. What does that mean, I've just had service and wof and all is fine. Why is this coming on sumtimes
The PCM (computer) is sensing an intermittent fault in one of the engine management components. A code reader will be needed to read any of the fault codes stored in the PCM. This would be the first place to start a diagnosis.
Jan 29, 2011 | Subaru Legacy Cars & Trucks
Identified as P0011
P0011 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
What does that mean?
Potential Symptoms:
Causes:
* Incorrect camshaft timing
* Wiring problems (harness/wiring) in intake timing control valve control solenoid system
* Continuous oil flow to VCT piston chamber
* Failed timing valve control solenoid (stuck open)
Possible Solutions:
Other related DTCs: P0010 - P0011 - P0012 - P0020 - P0021 - P0022
Hope helps (remember rated this).
Jun 25, 2010 | 2003 Nissan Altima
I have the code p0011,what is that?
Its a cam position timing sensor alert.
Usually if you have an oil change and code reset it stops coming up.
Apr 14, 2010 | Hyundai Sonata Cars & Trucks
CAR
Sep 29, 2008 | 2004 Volkswagen Golf
Top Umax Office Equipment & Supplies Experts
Michael Thomas
Michael Thomas
Mike
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
