Audio Technica Audio-Technica AT831B Microphone Logo
Posted on Jul 25, 2017
AT831b doesnt work. I've had it for years and pulled it out only to find there was nobody home. It did not have a battery in it. There deos not seem to be any visible damage to the unit. I looked at a current new one and noticed that the metal clip that makes contact with the positive end of the battery on the new unit its slightly different than the one on my mic. Any ideas on how to get this pup to bark?
I have a sony vlp vw10ht and the component red just recently seems to have faded out or stopped working. Is this a repairable situation?
Hello Dennis, please indicate, which device is connected to your Sony projector, indicate brand, model and type of device (DVD, VCR or other)
This projector has 3 Video inputs, two color inputs separately (Component Video) and one Composite video
I suggest you replace the cable between the projector and the image source and check if the problem is corrected, if you do not have another cable, try to connect some video signal to the Composite video input and see if it is missing the red color, If so, you would have a problem in the projector, if it looks good, the cable would be wrong
I hope you manage to solve the problem, comment the results
Greetings Franco Dosil
Hola Dennis, por favor indica, que aparato esta conectado a tu proyector Sony, indica marca, modelo y tipo de aparato(DVD, VCR u otro)
Este proyector tiene 3 entradas de V?deo, dos entradas de color por separado (V?deo por Componentes) y una de v?deo Compuesto
Te sugiero que reemplaces el cable entre el proyector y la fuente de imagen y compruebes si se corrige el problema, si no cuentas con otro cable, prueba conectar alguna se?al de v?deo a la entrada de V?deo compuesto y observa si esta faltando el color rojo, si es as?, tendr?as un problema en el proyector, si se ve bien, estar?a mal el cable
Espero que logres resolver el problema, comenta los resultados
Saludos Franco Dosil
https://www.projectorcentral.com/pdf/projector_manual_623.pdf
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
2answers
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 • Cameras
No signal
try a different xbox360 on the tv set and the cables you bought.
if it still doesnt work your monitor or tv tuner might be bad. if it does work then obviously your xbox360 is dead, even though the lights are ON nobody is home.
also make sure you have the right setting on the connecter switch, you will notice some have TV and HDTV leave it on TV. and try it.
If it doesnt work, Then Guess it time to buy a new one, unless its under warranty
then you might get a replacement
call microsoft or goto their website for more info.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
1helpful
Lost code kenwood auto radio
Hello, I`ve lost the code nummber for my Kennwood Radio. Trying very hard to recive the code number but nobody can seem to help me.Any ideas ?
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
