Question about LG 47LN5400 47" LED TV 1920x1080, 120 Hz. HDTV
No backlights, have sound, no piture on tv - LG 47LN5400 47" LED TV 1920x1080, 120 Hz. HDTV
Posted by Jeff Ciccarino on
cliffoa
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Check the cable. Possible bad HDMI (or whatever you use).
Posted on May 06, 2015
Piture goes off after a few min,s.sound stays on
Sounds like a bad inverter. They control the backlight to the screen. Check and replace, or contact a tv service tech.
Aug 07, 2015 | Televison & Video
My samsung tv la27t51b has no picture and only sound on dvd
You can go to near samsung service centre for best help.
thanks..
My Pahe : onsite training
Aug 07, 2012 | Samsung Televison & Video
How to fix my promac tv lcd 2051 lcd (sound but no piture)help me please
Back - light problem itself. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jul 25, 2012 | Televison & Video
L G LCD RZ-27LZ55 TV NO PITURE
If you are sure that the backlight board is good and that correct power is reaching your board then you might have a problem with the bulbs themselves. Also make sure that the board is grounded.
www.interliquidparts.com
Feb 24, 2012 | Televison & Video
Our philips lcd tv picture turns off but sound stays on and then the piture won't come back on for longer while.
Suddenly, the sound for LCD 42PFL3605/12 dissapeared. Resetted to factory settings, upgraded firmware, but no result. The TV ran just 24 hours. Please, help!
Dec 19, 2010 | Philips 47PFL7403D 47 in. LCD TV
LG RZ-37LZ55 LCD TV no piture or sound. Set popped prior to probl
just repaired mine same problem
available on ebay ( lg power supply repair kit £17.99 does the job well
Jan 01, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
How to unlock my rca tv
unlock?....does the set have no sound and piture? does the green light flash. i dont think this set locks like that you can lock out channels.
Dec 08, 2007 | RCA HD56W66 56" HDTV
Problem
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Oct 30, 2007 | Sony KP-61HS30 TV
Open Questions:
LG 47LN5400 47" LED TV 1920x1080, 120 Hz. HDTV Logo
145 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
