Question about Krups Ea9000 Barista Espresso Machine
How do you remove brew unit - Krups Ea9000 Barista Espresso Machine
Posted by Graham Langley on
Ross Keen
  • Krups Master
  • 1,364 Answers
I have done XP9000, this may be similar. Remove side cover, operate lever on side of exposed brew unit and pull brew unit out with the handle. You can only do this when machine is in normal 'at rest' position. Unit will not come out in any other position.
Posted on May 07, 2015
"brew unit block" medium cup in service mode dont work only the small cup works
When the alert came up- Brew unit blocked- this is before you started taking things apart, A, were you able to remove brew unit, Yes or No?
B, after turning power on and then off, Did the machine try to reset brew unit to home position Yes or no?
If Yes were you able to remove brew unit?
Aug 18, 2014 | Miele CVA615 Espresso Machine
How to remove the back wall behind brew unit on miele cva 615?
The Brew unit present switch is located on the brew unit drive. On the 615 model not an easy feat - the top and back have to be removed as well as the electronics - the micro switch has an extension arm on it the can fall off if the brew unit hits it the wrong way - I am guessing that is what may of happened here
Jun 19, 2014 | Miele CVA615 Espresso Machine
Sometimes the pucks do not fall into removable container. How do I fix this?
Make sure the swinging arm at the top of the brew unit moves easily. Check nothing on the brew unit is damaged. Servicing the brew unit might help.
Brew Unit
The transmission can wear out prematurely due to the brew unit becoming stiff. The piston in the brew unit should move smoothly and fairly easily. Keep the brew unit in good service by occasionally removing the piston to clean and re-grease the two big red o-rings using a food-safe grease. To pop the piston out the top, gently remove the plastic u-clip from the base of the shaft underneath, paying attention to which way up it goes for reassembly.
Jan 22, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Brew unit blocked message The brew unit removed and switches jumped, motor turns message still blocked brew unit . what could it be and ways to tests.
I had the same issue. Very difficult to fix. You must remove brew unit and reset the machine while apart. You must trick the machine to think brew unit is installed and door closed. Look at door and brew unit and use screwdriver or butter knife to engage machine and run through cycle to reset.
Jul 09, 2011 | Starbucks Saeco Italia Digital Barista...
I have a Miele Coffee Machine (built-in) CVA 620-1. I got a message saying the brewing unit is blocked. I removed the waste unit, a procedure that has to be done before you can remove the brewing unit. ...
The brew unit has lose parts on left-hand-side, wiggle them up and down. Put the waste unit back, switch off the machine and then turn it on (pull the cord). It worked for me!!!
Sep 14, 2010 | Miele CVA615 Espresso Machine
Jammed brewing unit
Remove the brew unit and check the screen under the red o-ring, find the 2 screws above the top piston and make sure the chamber that leads out to the tube is clear.
Mar 28, 2010 | Solis Master 5000 Espresso Machine
Insert Brew Unit
hi
If the brew unit (the dark gray thing inside that has "push" on it) is not locked in, you get this message.
Push in the center of the brew unit towards the back and see if you hear a click? If you don't, remove the brew unit and look in the back. Behind the brew unit there is a recess. Inside the recess is a verticle slot. There should be an arm the moves from top right to bottom left. If you don't see this arm, thats your problem. It will have to be serviced to replace the arm. Its caused by inserting the brew unit with the funnel down (not locked up). Remember to push the "Push" lever before inserting your brew unit.
Jan 01, 2010 | Saeco Incanto Classic Espresso Machine
Cleanded brew unit as instructed - brew unit miss error
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Aug 30, 2009 | Saeco Royal Digital Plus Coffee...
Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
Not making espresso from beans
Hi
Are your coffee grinds wet? If they are you have a clogged brew head. Remove the filter screen. Then remove the 2 screws that hold the outlet manifold to the brew head. There are 3 things under the manifold. O-ring, tapered spring and a crystal ball. Don't lose any of these items. Now to clean the brew head turn the brew unit over to where you can see where the brew screen was. You will see 2 holes, 1 large and 1 small. Take a paper clip and straighten it. Turn the brew unit upside down and insert the paperclip into the small hole. Push the paper clip through and remove the plug. I have seen them over 1/2" long. Reassemble the brew unit crystal ball first, small end of the spring on top of the crystal ball, place the o-ring over the spring and place the manifold on top making sure the outlet pipe is to the outside of the brew unit. Put the 2 screws back and your ready to go. Run a detergent for espresso machines like Cafiza through the brew unit every once in a while to keep it clean. It doesn't take a lot of detergent and use the pre-grind setting and a large cup selection but don't put any coffee in.
Nov 25, 2008 | Saeco Royal Digital Plus Coffee...
Krups Ea9000 Barista Espresso Machine Logo
271 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
