Question about GE GSS25SGPSS Side by Side Refrigerator
GE Refridgerator Not Dispensing Water
I have a GSS25SGPA SS refridgerator that is not dispensing water at the door. I replaced the solenoid valve and now get water all the way to the coupling at the base of the door. I see per a schematic of the door that there is another valve in the door assembly. Could that also be the issue? I've read a few places that the water lines on these models freeze periodically. Suggestions?
Posted by tsouthard156 on
Mike Smith
  • GE Master
  • 1,606 Answers
The waterline inside the door is frozen . Best way to thaw is .....1. open the door and tape the light switch down to keep the light off and the fan working . 2. tape plastic (trash bag , drycleaning bag..etc) over the entire freezer opening so the food will not thaw and the fridge will continue to work as designed . If possible 3. disconnect the water coupling behind the kickplate so air can enter , helping the door defrost cycle , or , leave the coupling connected and ocasionally walk by and press the water dispensor to see if thawed . 4. turn your freezer setting to a lower temperature ! to keep this from happening again .
Posted on Jul 11, 2009
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
LOUD BUZZING SOUND WHEN DISPENSING WATER THRU THE DOOR
The water control valve on rear of refrigerator is weakening. That is typical sound for a coil that opens the side that dispenses water or ice tray refills to vibrate or buzz when weakening. If I had you r model number I could give you the part number. They are not expensive and easy to replace. Thanks, Sea Breeze
May 06, 2010 | Maytag Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser on our GE Adora refridgerator (DSS25KGRA) stopped dispensing water. The internal icemaker still makes ice and the door unit dispenses ice both cubed and crushed. Could the water line be...
Most of the time it is the half of the dual water control valve on rear of refrigerator. The part number Click Here=> WR57X10032 Usually the coil on that side will go bad before buttons or controls. You can test that side by setting a test meter on AC voltage and you should read 120 volts while someone presses dispense water on front. There are two sides one plugs into icemaker side and other water dispenser. When replaced they both come as a kit. If you would like you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Water not dispensing ,side by side gsh25sgpa
make sure the water line is not kinked behind the refridgerator.
Jul 04, 2009 | GE GSH25JFR Side by Side Refrigerator
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
Ice Maker Isn't working
water to the foutain is not the same water to the ice maker . ck the dual water valve ..
Mar 25, 2008 | GE PFSS6PKSS
Maytag refridgerator leaking water down the front
It sounds as though you may have a 'dodgey' water solenoid valve which is allowing a constant flow through the valve. When the water enters the cabinet it goes into a double solenoid valve which splits the suply to the ice machine and the water supply. This valve can get limescale build up preventing it from closing properly. This is really the only control you have over the water supply. The solution I would suggest is replacing this valve. However I would suggest getting a professional to do this as you would then get some sort of guarantee on the work carried out. This valve is located on the rear of the cabinet normally on the RHS. Hope this is of some help.
Sep 11, 2007 | Refrigerators
Water not dispensing at the door
I have the same model and have had to clear frozen water lines frequently. There is nothing in the line between the bottom coupling and the outlet. The only thing I have had work consistently is turning off the freezer and letting the line thaw. I have never tried to get inside the door. Light suction from the upper end, such as by a vacuum pump, with the lower end of the hose out of the coupling and placed in a pan of hot water, will sometimes speed the process. I'm about ready to replace the entire refrigerator.
Aug 14, 2007 | GE GSL25JFPBS Side by Side Refrigerator
GE GSS25SGPSS Side by Side Refrigerator Logo
549 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
