My PC worked very well for several hours although it has only 186 megabytes of unused space. I clicked to power off/close the computer and it shut down correctly but when I attempted to power on again, I only got a white screen. THIS HAPPENED ONCE BEFORE AND I SOLVED THE PROBLEM BY SIMPLY NOT USING MY COMPUTER FOR SEVERAL MONTHS. WHEN I POWERED ON AGAIN, THE PROBLEM SEEMED TO HAVE BEEN SOLVED. WHAT NEXT? I'M GOING TO SOLVE THE PROBLEM WITH LAPLINK DOT COM. MEANWHILE? Just prior to shutting down, I noticed that the screen went white if not positioned carefully.
Wild guess with such a small amount of unused space your system has no room to "play with". Your Idle time "repair"
may indicate Hard drive issues. If you have critical data on the drive you need to backup. I would put the laptop in the freezer if you can find space, overnight. Then try to boot to "safe mode" F8 key I believe. Do Hdd error check. Worst case, you may need to reinstall operating system with potential loss of data.
Testimonial: "Thank you. Might the F8 key work even if I have a white screen? I wonder whether the small amount of unused space caused the white screen and I wonder if I have a short circuit or loose plug in the screen/lid itself (but NetZero should be able to stop this and I use NetZero). In the past, I solved the problem by powering off, unplugging the adapter cord, removing the battery, letting the T-23 cool for 5 hours or more, reinstalling the battery then plugging in the adapter then powering on. When I get the screen to work again -- one way or the other -- my next step is to install PC Mover Pro Office (by http://www.laplink.com) -- 20 - 25 megabytes. I have a Dell Workstation tower just for data storage and the laplink dot com technician (Sun., 19 April, 2013) told me that the tower only has to be online for a few minutes. I don't see any reason why my IBM T-23 should have too little unused space (in the future). I think that I'll have a great laptop PC once we solve the white screen problem. My remarks must be anonymous because I don't need a burglary. Otherwise, I'd tell the world who I am proud of my efforts."
When you plug the AC adapter the power LED and the battery charge LED light up. When you press on the power button the laptop powers up but will not start. There is no video on LCD or external monitor.If the power LED lights up it indicates that the laptop is getting power from the AC adapter. Most likely there is nothing wrong with the adapter but just in case test it with a voltmeter to make sure the output voltage is correct.
When you press on the power button, the laptop makes a series or short and long beeps and will not start up. There is no video on the screen.In this situation test the memory module as I described in the situation2. Try installing a known good memory module. Most likely you are getting a beep error because of a faulty memory.
You start the laptop. It sounds like the laptop is booting normally (hard drive LED is flashing) but there is no video on the screenIn this situation test the laptop with an external monitor. If the external screen works fine but there is no video on the laptop LCD, most likely there is a problem inside the laptop display assembly. Go to my previous post witch covers laptop video problems in more details.
You start the laptop and it starts making repetitive clicking noise or grinding noise.Most likely you hear this noise because of a faulty hard drive. You can remove the hard drive and start the laptop without it. If the noise is gone, the hard drive is your problem. Replace it.
The laptop boots into Windows ans works for a while, but after that it shuts down by itself without any reason or warning. You restart the laptop but the same problem appears againMost likely it's a heat related issue. Listen for the cooling fan, make sure it works.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
