Washing Machines Logo
Question about AEG Washing Machines
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Dado
    Master:
  • AEG Master
  • 511 Answers
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
Posted on Jun 09, 2015
2 Related Answers
Anonymous
SOURCE: AEG Lavamat 62800 keeps stopping
AEG Lavamat 62800 keeps stopping and displaying error E50. What is the problem and how do I fix it?
Posted on Apr 23, 2012
mike cooper
  • 884 Answers
SOURCE: What's your problem?AEG Lavamat 62800 keeps stopping and displaying error E50. What is the problem and how do I fix it?
Believe this is a motor fault. Change the brushes as a first fix attempt.
AEG Lavamat 60810 E50 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
E50 does mean problem with motor or tachometer placed on the motor. Could be: worn carbon brushes, motor faulty, wiring, electronic faulty.
E70 does mean problem with heating phase.
Could be: NTC sensor faulty or badly positioned, wiring faulty, electronic faulty.
Dado
AEG Lavamat 60810 E70 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
First of all, read exactly alarm code.
Press "Spin/Rinse hold" button and "Prewash" simultaneously for at least 2 seconds: the LED switch off and then display the
sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down. During the time the alarm is displayed, the appliance continues to perform the cycle or, if it is in the
selection phase, it keeps in memory the options previously chosen.
E70 - Family alarm code
  • E71 - Washing NTC sensor faulty
  • E74 - Washing NTC sensor badly positioned
Causes: NTC sensor badly positioned; NTC sensor faulty; wiring faulty; PCB faulty.
E50 - Family alarm code
  • E51 - Motor power supply triac short-circuited
  • E52 - No signal from motor tachometric generator
  • E53 - Motor triac sensing circuit faulty
  • E54 - Motor relay contacts sticking
Causes: Motor faulty; wiring faulty; PCB faulty; current leakage from motor or from wiring
Dado
Aeg lavamat 63613 error code E70
Family error code E70 is shown to the customer. In service mode could be: E71 or E74
Dado
2answers
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
7helpful
3helpful
2answers
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
3helpful
2answers
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
11helpful
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Top AEG Washing Machines Experts
john h
W.L.
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
