SOURCE: 1995 caprice clasic blows steam on windshield
you should be able to go under the dash on the passengers side to get to it. if you look where the heater hoses go in the engine compartment it will tell you how far up you have to go inside.
SOURCE: no heat just warm air
I think you are on top of your problem,,you dont need any one elses advice.
Complete rebuild of the cooling and heating system,, simple.
SOURCE: fuse for locks constantly blows
Try replacing the relay. Clean the socket of the relay and fuse
SOURCE: my cigarrete lighter doesnt work,
all you need to do is buy a cheep test light in the 5-10 range. ground the test light and touch the metal in the fuse you do not need to take the fuse out. check both sides of the fuse you will see 2 metal pices on the back of the fuse were it tells you how many amps the fuse is. that is what you touch with the test light. the light should light up if not the fuses are bad. if the fuse is good take the test light and ground it again you can clip it to the side of the cig lighter socket. and put the test light prob into the cig lighter socket becarefull not to touch the sides of the socket and just touch dead center bottom and if the test light does not light up you know your Cig socket has burnt out
SOURCE: 2004 Cavalier (4Dr Base) just purchased: Driver's
i don't think so, you'll probably just have to replace it if the dirt is on the inside
