I have already tried codes listed in another answer, 671, 748, 750, and 649. None of these control the volume on my sound bar. Are there any additional codes which might control the Nakimichi NK12?
To whom it may concern,
1.) Point the remote towards the desired device you'd like to control.
2.) Press and hold the "tv" button at the top right hand side of your remote until all the top buttons begin flashing red.
3.) Press the small red power button at the top of the remote one time.
4.) Slowly and repeatedly press the down key on the directional pad until your device powers off.
5.) Once the device powers down, at the bottom right hand side of the remote underneath the keypad.. press the # key.
The "tv" button will flash red three times, and then your remote is linked to the box.
dish guy
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brian_142c5ec89a7a3fda
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
SOURCE: need codes for a phillips magnavox for dish network controller
Follow this link and got to the remote section. Once there shoose the type of remote you have and select remote codes to get the ones for that particular remote that may operate the piece of equipment desired. I hope this is of assistance to yoiu and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
SOURCE: need phillips magnavox code to put into dish network remote
I'd be happy to help you with your request. The codes you are looking for are:
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
If you are satisfied with my assistance please use our rating system to evaluate my service. Thanks for using Fix Ya!
SOURCE: i need codes to program my vizio sound bar to my
need 3-digit code to program Vixo sound bar to Dish Network 5.4 IR remote
SOURCE: programming codes for dish network remote control
The following link will take you to the website where the codes are located:
http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotes/8.0.shtml
Thanks for using Fix Ya.
Hi Gw, my name is Mike Houston a Social Media Representative at DISH. I understand you want to program your innvoage remote to our DISH receiver. When we send out our DISH receivers we will include our own DISH universal remotes that can control many different components like; HDTV, surround sound receivers and sound bars. We do not have the codes for other universal remotes to work with our system. I will provide you a link explaining in more detail on programming your remote: http://www.ehow.com/way_5501311_innovage-jumbo-universal-remote-instructions.html
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on
the remote, about one press every two seconds. Stop as soon as the sound bar turns
off. This process may take several minutes.
4. Press POUND (#) on the remote. The VCR MODE button will
flash three times.
(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press
VOLUME on the remote to confirm the remote controls the sound bar. If this does not
work, return to Step 1.
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
