The screen flashes when I change sources but never resolves itself
Problems can often occur with even relatively new Samsung LCD, LED Television. Some customers report their screen going black shortly after turning on the television, and flickering picture even though the TV's speakers continue to produce sound. You can test and rule out a number of things before concluding that your TV has a hardware defect.
First, check the input settings of your television. Often, users will experience a dark screen when first turning on their television if the selected input corresponds with a turned-off or unplugged input, such as a gaming system or DVD player. If the problem persists, try reconnecting all cables on the back or sides of the television. It's possible that one of your cables has gone dead. If you have access to other cables, try swapping these in and see if the problem persists. Some customers report that turning the television off and unplugging it for an extended period of time, up to 24 hours, can fix the black-screen issue.
Samsung TV - Power Supply Issues
If you've tried all of these suggestions and problems persist, it's possible that the power supply inside the television is defective or broken. The power supply for most Samsung LCD, LED televisions will cost around $150, with labor costs of around $250. Unless you have a fair amount of TV repair expertise, this is probably not the sort of repair you'd attempt yourself.
If resetting the OSD doesn't work, then you probably have a physical problem with your Menu button. Sometimes, particularly on older machines, the connections to the circuit board are dirty or failing. Because you have to actually get into the monitor itself, you will probably void any remaining warranty by attempting this fix. If your monitor is still under warranty, contact the manufacturer to see if there is a local repair shop that can help you.
If you want to tackle this issue yourself, grab a screwdriver and take the plunge. Remove the casing on the monitor itself and locate the contact switch for the menu button on the circuit board. Sometimes, just working it with your fingers or a screwdriver is enough to unstick it - you can try to clean off any dust or grime that has accumulated around it to see if that is the cause.
