Polaris 2009 Sportsman 850 EFI XP With EPS Logo
m
michael pAUL BECKER Posted on May 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Behind starter fly wheel only moves back not forward wil not start not start starter seems like its working spins
Renee Knafel-Bullock
Level 3:
Master:
  • Master 404 Answers
  • Posted on Oct 24, 2015
Master
Level 3:
Master:
Answers
404
Questions
Helped
152150
Points
1156
Remove the starter and replace it engaging the teeth sequence so they are locked together, you cant just put on on it without interlocking the teeth, take it loose then reposition it with teeth engaged then tightern bolts and solenoid you are good to go.
jabberwoky
Level 3:
  • Master 739 Answers
  • Posted on May 03, 2015
jabberwoky
Master
Level 3:
Answers
739
Questions
0
Helped
229846
Points
3082
Disconnect the battery and then carefully remove the starter. Take the unit to a local auto parts dealer for a bench test. Starters have two separate functions, one spins the shaft to crank the engine, the other is called a bendix, which pushes the starter gear out to engage the flywheel, and then after the engine engages, retracts it (except in the case of starter/generator combo units which recharge your battery and power your vehicle's electricals while the engine is running) Always best to get a bench test rather than depending on apparent symptoms.
I have an 2003 kodiak 400 2 wheel drive and the starter not engaging it just spinning I know the starter may be bad just seeing before buying new one if I can make it work again I read somewhere it moves...
I don't know about your atv - most car and truck starters move into mesh before receiving full power but many bike type starters use a roller clutch in a drive that is a permanent chain drive.
I strongly advise you obtain the appropriate service literature for your machine before you start to unbolt anything.
Jan 20, 2021 • ATVs
2answers
Starter spins but don't engage and won't start please HELP!!!! This is on a Polaris RZR 800s 2013
Check to see that the pinion gear of the starter is hooting out and engaging the flywheel.
And if it is working it is possible that you have missing tooth/teeth on your flywheel and the starter cannot turn over the engine because of that.
Have a 200cc chinese quad. I think its an air cooled Lifan engine. I can hear starter motor spinning but dosnt turn engine. any advise would be apreciated
Try taking a look at the starter and flywheel while attempting to start the engine. Does the small gear at the end of the starter move forward and engage the flywheel when you try to start the engine? Could it be stuck? The small gear must move forward to engage the flywheel. Keep your fingers away from the moving parts.
Why electric start does not work and pull start works
1. Need a new battery
2. starter solenoid is defective
3. starter needs rebuilding...
Does Solenoid click when trying the electric starter? CAREFULLY jump the two terminals on the solenoid (SPARKS WILL FLY).. IF the engine turns over or starts, THE SOLENOID IS BAD. just replace it.
If it clicks when you are trying to start it electrically, use a multimeter (voltmeter) to see if you are getting 12v to the starter connection while you are trying to electrically start it. (+) lead on starter bolt and (-) to a motor mount bolt. If you get 12v+, starter needs rebuilding!
Why is my outlaw fly wheel maqking a grinding noise when trying to start
Try using the pull start.If it dosnt grind this way its probably not your flywheel,most likely the starter.Have it cleaned and oiled.
3answers
2004 arctic cat 500 4x4 starter turns doesnt engage starts with pull cord
The starter has to throw it's gear out using centrifugal force. The speed of the starter has to be enough to overcome the spring inside. It is either a little seized and needs to be rebuilt and greased up, or the battery isn't powered up enough to get the right speed to engage properly. In that case clean the battery posts and clamps well, then charge or replace the battery. To know if the battery is bad wait till it is charged... if it still doesn't engage try again with booster cables from your car etc. and see if it suddenly works fine.
I have purchased a 70cc Zuma Quad seems extremle heavy on steerin wen still also seems to still go straight wen wheels are turned on full lock. Any suggestions
fully locked with a bridge in this case, still carrying the wheels atv `s straight-in this case, you need to shift your weight forward.
Have I got correctly still understand that you are behind the wheel locked and the atv is not enough to turn while driving?
Oct 24, 2013 • ATVs
I have an ATV Polaris Sportsman 800 that will not go into 4WD while in reverse with the over ride button pressed in. It did not work one day then worked the next and now seems to be out for good. 4 WD...
The over RIDE button is not used for shifting.
it is used to over RIDE the REV LIMETER while in reverse ( for applications such as plowing)
shifting into 4wd while moving is safe on some vehicles, but can cause catastrophic damage on others.
be ABSOLUTELY sure your vehicle is designed for SHIFT ON THE FLY .
If you aren sure, then come to a complete stop befor shifting.
Nov 30, 2017 • Polaris ATV
Top Polaris ATVs Experts
john h
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Polaris ATV Expert? Answer questions, earn points and help others
