Question about Fujitsu ASU12RLS2 Wall Mounted Indoor Unit Air Handler 12,000 BTU 1
Branch unit gets no power from base unit - Fujitsu ASU12RLS2 Wall Mounted Indoor Unit Air Handler 12,000 BTU 1
How do I pick the perfect pole saw?
Want to saw up high, but think it's dangerous to saw on a ladder? Good thinking. So how can you get your saw to reach those high branches while keeping your feet planted on the ground?
Take a lightweight chainsaw, add a stick, and you get a pole saw.
TYPE There are three types of pole saw. You can choose any one of them based on your requirements.
CORDLESS POLE SAW Cordless pole saws are said to be the handiest pole saw as it removes the hassle of carrying wires and cords during pruning. It operates through a rechargeable battery. But, due to its battery pack, its operation time is very specific. If you want to extend the time for heavy duties, you can use extra battery packs.
One of the best advantages of cordless pole saw is its need for low-maintenance. You would hardly need to maintain its well-being.
GAS POWERED POLE SAW Gas powered pole saws are mostly chosen by the professionals for its heavy-duty bars and chains and have the power to cut huge and large branches with ease. This pole saw can be extended up to 9 inches so you might distinguish its expertise in trimming high rise trees. It is good for regular use. It is heavier than the electric one and noisy also. Despite being heavy, you would not face any problem working with it as the pole saw is easy to balance.
ELECTRIC POLE SAW Electric pole saws are preferred for small branches trimming as it has blades of 6"-10". It weighs about 10 pounds that means you can carry the saw effortlessly. It does not require high maintenance as well. Plug the long extension cord before you start, aim at the branches and begin pruning with this electric pole saw.
More details
Guide on How to Pick the Perfect Pole Saw
Apr 16, 2018 | Garden
Tip
Fixing the handset link to base unit of Panasonic KX-TG4500
After the base unit died I was able to restore power by switching out the power adapter of one of the handsets with the one on the base unit. However, when the power was restored to the base, none of the handsets that previously worked were getting a dial tone. I could only use the phone from the base unit. To fix the handsets I first reset the base unit by pressing the reset button with the tip of a pen on the bottom of the base phone then momentarily removed and reinstall the battery on each of the handsets to allow each to reset individually. In doing so, I got the dial tone back on all previously linked handsets without having to reregister them.
on Mar 23, 2010 | Lands Phones
How can I use a gas pole saw?
Congratulations on getting you a new gas pole saw! A gas pole saw is undoubtedly the most powerful of pole saw types. It uses gas for operation, heavy-duty bars, and chains and is effective for a longer working period. Since it is the most powerful; you can put your faith for pruning heavier and larger branches and trees.
So, you have chosen rightly. But, it is a matter of concern, if you do not know how to use a gas pole saw. Let us help you with this matter.
BEFORE YOU START
  • Make sure that the pole saw is safe and prepared to be used. The faulty ones can lead to a serious accident.
  • Clear the area where you would use your pole saw and where the limbs would fall. Any hazard should be cleared at once.
  • Be aware of the weather because the windy or rainy weather can turn your pruning into a dreadful experience.
  • Cut only one limb at a time
  • Avoid cutting branches that are thicker than 8 inches. Take expert's help in this matter.
  • Be aware of the kickbacks.
  • Always maintain the right balance and base. Hold the saw firmly and stay at your place rigidly.
These instructions should be taken into account before the start of trimming. After you follow the instructions given above, it is time to move towards pruning process. The steps below lay out how to use a gas pole saw.
STEP 1 As you hold the grip of your pole saw and make a balance of your position, make few jump cuts underneath the branch you want to cut off. Jump cuts are a necessary technique which is used before the final cut. It reduces the weight of the branch that makes the final cut easier. It can be physically challenging to cut from underneath. So, always pick a pole saw equivalent to your weight bearing capability.
STEP 2 Extend the height of the pole saw based on the height of the branch. Hold the pole saw vertically, take it up to the branches away from the ground and never forget to hold it properly. Adjust its position and let it rest on the branches. In the meantime, you can ensure your position too. Always keep the pole saw at your chest level.
STEP 3 Now, begin to cut perpendicular to the limb and try to make deep cuts as much as you can. Deep cuts will let you make the final cut and other cuts easier. It will also allow you to make faster cutting strokes. Readjust your position, and the pole saw if you face any trouble.
STEP 4 The last step is all about your safety. Check where the limbs are falling and move from that place as early as possible.
Do not lose hope if you fail the first time. Keep trying until you reach your full potential. Clean the work area after trimming is done. So, this is how you can use a gas pole saw. Keep pruning and stay safe!
More details open the link Guide on How to Use Gas Pole Saw
Apr 11, 2018 | Garden
Tatarian Maple leaves growing out of trunk, should I remove those branches or buches clear from the ground up as that is how they are growing?
G'day Patti, unless you want to look beyond the tree it would be advisable to leave the lower leaves and branches. The lower branches hide little critters from big critters. Cheers Greg.
Jun 11, 2016 | Garden
What is a group of trees
Huh, ...?
i thought a 'group' of tree's, was a - FOREST!
Apr 14, 2015 | Computers & Internet
A branch on my blue moon rose broke off can I save the branch its quite big and heavy and has dead wood at the base
You can do whatever you want with it, save it, throw it out, give it as a gift.
Oct 25, 2014 | Cars & Trucks
Please tell me whether it is a company for computer engineers or students from electronic & communication branch also??
Lufthansa is a global airline company based out of Germany. While technically not for computer engineers, it stands to reason that they would hire many. Students from electronic and communication branches could also probably find work in one of their business segments.
Mar 25, 2011 | lufthansa.com
Turn off the power
you have a short likely in the machine.
more importantly......
you have a defective electrical system in your house.
the branch circuit should trip before the main. the fact that the entire house shuts down means the main breaker is tripping, and not the branch circuit for the unit.
this is dangerous. you could have a fire very easily as the wires in the walls can become heated.
there is no good explanation why the main trips rather than a branch circuit. get a qualified electrician out to make your home safe.
the only other thing i can think of is that you have a very small service, and your total usage just happens to exceed the capacity of the main each time your cycle gets to between 1 hour and 1.5 hours. incredibly unlikely.
get this looked at before you have a tragedy.
really.
good luck
mark
Dec 17, 2007 | Indesit 24 in. D61 Free-standing...
CD ROM
Sorry AIO Is only based in Europe, USA, China, Taiwan, Singapore & Malasia, Maybe its best you replace your unit because It will cost you more to repair it anyway.
But if you need the contact details of AIO let me know and I will send them to you (specify which branch of AIO details you want) Thanks.
Regards.
Nov 09, 2007 | Future Power AIO Motherboard (S3PMFPN)
Fujitsu ASU12RLS2 Wall Mounted Indoor Unit Air Handler 12,000 BTU 1 Logo
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
jdthefixer
Muntejaya Ginting
Muntejaya Ginting
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
