GE remote control have no set-up code to Sylvania brand TVs. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
SOURCE: i need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
SOURCE: remote codes
GE ........... 0704 0312 0018 0002 0502
................. 0006 0007 0601 0835 0901
................. 0114 0103 0803 0806 0310
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
SOURCE: lost code for my ge remote model # rc24912-b
heres all the codes for that tv one of them should workSYLVANIA ................ 0062 0004 0009
................. 0135 0189 0183 0227 0456
................. 0008 0068 0075 0141 0161
SOURCE: rcr312w universal remote control, I need codes for sylvania tv/vh
Sorry it took so long to respond to you request for help.[ Sylvania TV Code-1251, VCR Code-2154 ] These are the listed code for your model remote control and the Sylvania television and vcr combination unit. I hope this information solves you problem of needing codes to use your remote control with you television and vcr combination unit. Thank you for using FixYa and have a nice day.
