Question about Electrolux Guardian Bagged Canister Vacuum
Electrolux vacuum power bar not turning
I have an old Electrolux canister. The powerhead light is on, and the vacuum is working- but the bar isn't turning. What is wrong?
Posted by dsim780685 on
jlkowerysr
    Scholar:
  • 70 Answers
First thing is to push the circuit breaker button(reset button). If that dosen't work, check the belt. It could be broken.
Posted on Jul 15, 2009
Philip Long
    President:
  • 1,486 Answers
Check the belt driving the bar.Its either come off or broke.
Posted on Jul 10, 2009
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Power head turns on and off as the unit is vacuuming
Probably not hose but more then likely is a problem within your wand. Try connecting your hose handle directly to your powerhead and see if you can get consisten power. I work in customer service for electrolux and more then likely it is in fact the wand
Jul 17, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The powerhead stop working followed by the entire canister not working. There are no lights and nothing funtions.
this unit is made by eureka
just carrys eletrolux name
the original electrolux is now called aerus
Jul 12, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I havea -1year old Oxygen Vacuum and the powerhead just quit.
the vacuum you have is made by eureka (cheap)
the original electrolux today is called aerus
Jun 26, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
No power when its turned on
There was a (common cause) power arc during the swap (while running the vacuum).
The fuse located under the grey clipped-on plate of the canister is blown. The fuse is soldered-on the board and would need to be changed (board or fuse). Not "user friendly" zone. Warranty? Smart if they designed a breaker button instead of a fuse here...
Rick
Mar 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Canister - Renaissance model
Probably a clog, because the change bag light is nothing but an airflow sensor.
Check your hoses to ensure that there are no blockages, and also check inside the powerhead behind the brushroll.
-R
Aug 07, 2008 | Electrolux Lux 5500 Canister Vacuum
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux power nozzle not working
the powerhead gets its power through a connector adjacent to the hose connection to the vacuum end. there's two wires embedded in the hose which make its way to the handle, pipe and powerhead. take apart the handle and see if you can read continuity from one end to the handle switch.
Aug 06, 2007 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
311 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Colin Stickland
Colin Stickland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
