Question about Zebra ZM400 Direct Thermal-Thermal Transfer Bar Code
How to load new labels
I need to know how to load the new labels in to the zebra zm400 printer
Posted by killallthepe on
Joe Blow
  • 257 Answers
Http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Posted on Jul 10, 2009
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
How to fix dissapear printing label for Zebra ZM400
Hi, please be more especific regarding issue, can be software issue or hardware issue.
Jun 20, 2014 | Zebra ZM400 Thermal Label Printer -...
How to solve this problem in zebra zm400 error condition paper out \
check the sensor under the paper, reload labels roll, labels are possible on top of sensor black plastic and not between. move gap sensor to midle of label with. check manual to know how to fit the labels thought the sensors and printhead.
Sep 17, 2013 | Zebra ZM400 Thermal Label Printer -...
The print out of ZM400 misalign to the left. How to make it back to the centre of the label?
Printing from an Internet Browser can cause this result if you have not set the margins, footers, and headers.
File ' Page Setup
Change all margins to 0.01 (or as close as possible, it may override you) and all SIX bars below that to Blank or Empty.
Apr 10, 2013 | Zebra ZM400 Thermal Label Printer -...
How to downgrade ZM400 printer firmware
If the firmware here is the one you have, contact their support direct and ask them for the older version. You won't find it anywhere else.
ZM400 Industrial Printer Support Downloads Zebra
Jul 26, 2017 | Zebra Office Equipment & Supplies
Zm400 just keeps on spitting out blank labels even after a hard restart
It's possible the labels are not loaded correctly and are missing the label sensor. Be sure the labels are loaded all the way to the left, if you are looking at the front of the printer.
Jun 16, 2011 | Zebra ZM400 Thermal Label Printer -...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Software needed for ZM400
Try Zebra Designer, it is free from the Zebra website. If you'd like to link to a database, you will need to pay for the software.
Jun 30, 2009 | Zebra Z4Mplus Label Printer
Zebra ZM400 Direct Thermal-Thermal Transfer Bar Code  Logo
898 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
