My blower motor has locked up and I need to replace it but it appears to have been replaced once before with less than original equipment motor. I need to know what the original blower motor and capacitor specs are in order to correctly replace.
The motor specs can change from time to time depending on what the manufacturer has in mind.
If it has locked up check first and make sure the squirrel cage fan has not moved and is binding on the housing.
If it is clear to turn and wont turn,, the bearings must be bad, and this is probably NOT a problem with the motor being "wrong". Its just the way things are made.
Contact a RUUD distributor for the specs you request.
