Question about ScanSoft PDF Converter Professional (m109a-g00.2.0) for PC
How do I use the erase feature in Nuance's PDF
I am attempting to edit a PDF document using Nuance's PDF Converter vs. 4.0 and I have not had any success. How do I use the erase feature in Nuance's PDF Converter?
In version 5, You go to Comments, then Draw Tools, then Rectangle (or other appropriate shape). Hold down to make box and change characteristics to white on white with opaque. Accidental boxes can be deleted by pointing to their side lines until the arrow appears and then select delete (to set white on white, just click Properties instead).
Posted on Aug 28, 2009
    Scholar:
  • 57 Answers
Dsmith30 - I am using v 5 but as far as I recall v 4 is the same:
The erase tool only works on lines you have drawn using the "pencil" tool. It does not erase text in a text box.
To use the tool, choose "Comments, then Draw Tools, then eraser" from the menu. Hold the left mouse button while moving it, and it will erase whatever part of the drawn line(s) it passes over.
Michael
Posted on Jul 10, 2009
Tip
How to edit password protect PDF file
PDF file is playing a crucial role in our office,study life. We need to deal with these documents very often. In school, we write our paper and hand in PDF format to professor . In office, we archive files in PDF format. All these suggest that, PDF is quite a popular format to share our idea with others.
These mainly due to the stability of PDF, the practical and powerful features . Unlike Word format, it is not easy to edit for owners can add password to proteceted the pdf from editing,copying,printing. But excellent feature can become weak point because there is still some reason for you to edit these password protect PDF file, you do have the right but the password is lost .But as we all know, Adobe Acrobat wil cost us a lot. How to edit password protect PDF file is the main idea of these article.
Method 1 Use PDF converter
It has been my experience. First you should find a good PDF converter not online conversion , I won
on Dec 06, 2010 | Computers & Internet
Tip
How to Convert PDF to Word Document on a Mac ?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As we all know , PDF is a proprietary format that allows we to read electronic documents, either on or off line. But the problem is that it can not be editable and freezes the content . Facing with such problem, we need to convert pdf files to other formats. While, we always convert it to word , we all familiar with word which is an editable format .As mac user, you must want to know how to convert it perfectly, in this case , PDF Converter Mac is the best choice for you.
To begin with you should know the software which is called PDF Converter Mac, PDF Converter Mac is a comprehensive PDF tool to help Mac users convert PDF to Microsoft Office Word, Excel and PowerPoint for Mac. By converting PDF files to Office documents for Mac, Mac users can flexibly edit or reuse read-only PDF files, or extract PDF tables and data to spreadsheet for easier calculating and editing, or present PDF contents to the public. PDF Converter for Mac offers many amazing features: Good Preservation; High Efficiency; Support encrypted PDF Files Conversion; Flexible Options and more. With quick conversion speed and batch conversion modes, PDF Converter Mac can improve your efficiency to a large extent.
Now download this PDF Converter Mac to convert pdf to word on a Mac and install it to your computer, Following is the details on how to convert pdf to word step by step.
step 1. Import PDF Files
You can add them from the File menu or directly drag files into the panel. By the way, you can remove the file by dragging it out of the panel.
step 2. Customize Output Settings
You can set the files in the panel individually. Choose a file and click setting icon and you can customize the Page Range and Format.
The default option of Page Range is All pages; you can also choose Customize and type on the page number that need to convert.
There are two options of output format. You can choose MS Office Word (.doc) or Rich Text Format (.rtf) as your need. If you choose the option Apply to all, the format of current document setting will apply to all the files in the panel.
step 3. Set Destination Folder
You can set output folder by choosing File-output settings-output folder. There are two options to select. You can save the output file in the same folder as source or click Browse to customize the destination folder.
step 4. Convert PDF Files
Click Convert and all the files will be converted in seconds. There is a processing bar in the process of conversion. And after conversion, there will a notification to show you the conversion result. It will be found that all the original text, layouts, hyperlinks and graphics would be preserved in an editable Word document.
OK! You successfully complete to convet pdf to word in mac OS X with a few steps, you can use the word files easily now.
on Sep 21, 2010 | Cameras
Hello, i have 2 questions: 1- i need to know if there is away to convert "Arabic protected PDF book into DOC " 2- i need to know is there is away to supervise my team while the are dealing with...
PDF is the only document format that typically allows you to view the file, instead of editing with many means like data encryption techniques, passwords and local restrictions. Due to these actors, users prefer to convert PDF to Doc format so that they can access and make changes to the data. Once converted to Word format, files become open for modification, editing, printing, copying and extracting information. Using Doremisoft PDF to DOC converter is the most effective method to convert PDF to Doc with utmost ease and accuracy.This is an easy-to-use and efficient PDF to Word utility that converts PDF to Word DOC file with great precision. Good Preservation PDF Converter preserves all the elements of original PDF files, such as text, hyperlinks, images, layouts, tables, columns, and graphics. The best aspect about this utility is that as a user you can also convert password-protected PDF file. During the process of PDF to word conversion, the software prompts the user to enter the password. As a result, it is very important that the password of the PDF file must be known for PDF to Word conversion.Key Features of PDF to docx converter:
1.Support all Windows platforms, Windows Server 2008, Windows 7, Windows Vista, Windows XP, Windows 2003 and Windows 2000 2.Provides complete support to the conversion from encrypted PDF files and password protected documents 3.Preserves the Text, Pictures, and Layout even after the successful conversion of file from PDF to Word DOC format 4.Supports Unicode Character Conversion 5.Perform the PDF to DOC conversion at a very high speed 6.Allows user to convert entire document or only a specific page range 7.Converted files can be automatically opened immediately after conversion complete 8.Provides round the clock technical support 9. Preserve data structure, formatting and properties of content 10. This PDF to Word Converter is compatible with Microsoft Office 2010, 2007, and 2003.Pricing and Availability:Doremisoft PDF to Word converter is priced at $39.95 for single user license. You can downloaded online from Doremisoft pdf to word converter website
Sep 22, 2011 | Microsoft Office Professional 2007 Full...
I need convert a pdf to word doc. how can i do that?
PDF to word doc conversion process is very easy. There are many application available to the conversion but i have used Kernel for PDF to Word application to this conversion. It is an advance and cost-effective program so you can also try it. Visit software link http://www.freepdftowordconverter.net/
Aug 01, 2010 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
How do you erase text from a pdf file?
Chances are you're using Acrobat Reader to read the PDF (portable document format) file.
You need Acrobat "Writer" (aka Distiller) to actually make changes to a PDF file, as the reader can only read the image file itself.
Jun 19, 2010 | ScanSoft PDF Converter Professional...
How do you scan a paper to a PDF file on dell
Scansoft (or Nuance) PDF Converter 3 is a useful utility for converting documents to PDF files
Mar 02, 2010 | Dell 1815dn All-In-One Laser Printer
ScanSoft PDF Converter Professional (m109a-g00.2.0) for PC Logo
5,149 people viewed this question
Top ScanSoft Computers & Internet Experts
Al Rush
Barbat Nae
Barbat Nae
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
