XFX NVIDIA GeForce 8600 Graphics Card Logo
Posted on Jul 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Should i buy this graphic card i want to play arma 2 i have pendtium d 3.00 ghz and 2 gb DDR 2 667MHZ RAM
Anonymous
Level 2:
  • Expert 79 Answers
  • Posted on Jul 10, 2009
Anonymous
Expert
Level 2:
Answers
79
Questions
0
Helped
26862
Points
235
Arma 2 is badly optimized, you should run it with that card, but only on minimal details, I would look for something more powerful, for example ATI Radeon HD4770 is cheap, power efficient and very powerful
HOW TO FIX ERROR 80070002
The problem is with your graphic card G33/G31. Since its an Integrated graphic card you need a dedicated GPU to run games on decent settings.Earlier i had the same graphic card and i can only play games from 2005.This GPU is too weak to run such games. I suggest you to buy a new dedicated graphic card.
What would be the best compatible 512 MB GPU(with shader 3 or 4) working with P4I45GV 3.00 /P4 2.4 GHZ/1 Gb ram ?
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
Any of them Shubham.
If we are to discern by a few known statements;
1) It is believed in some 'geek communities', that using the same manufacturer of motherboard chipset, and graphics chipset; to be a good thing.
For example an AMD motherboard chipset 'plays well' with an AMD ATI graphics chipset;
Nvidia motherboard chipset 'plays well' with Nvidia graphics chipset.
Intel motherboard chipset with Intel graphics..............no wait,....... there is no Intel graphics chipset, unless it is -> Integrated Graphics.
[ Intel GMA ]
(Integrated Graphics is also said as OnBoard graphics. ON the motherBOARD)
2) DOES NOT MATTER what graphics memory type is used.
Motherboard can use DDR Sdram ram memory, and graphics card can use GDDR5.
Why?
Because the graphics card has it's own Processor, and Ram Memory.
Graphics Processing Unit, or GPU; is the Processor,
http://en.wikipedia.org/wiki/GPU
Graphics memory is the ram memory.
Operates independent of the system resources.
The graphics expansion slot on the P4I45GV (P4 i 45GV), is an AGP slot.
Accelerated Graphics Port,
http://en.wikipedia.org/wiki/AGP
It will use an AGP 4X, or AGP 8X graphics card.
Use an AGP 8X.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=agp+graphics+card+512mb
REMEMBER;
1) ALWAYS follow Anti-Static Precautions.
2) INSTALL the software for the graphics card F-I-R-S-T,
(Drivers and 'control panel')
THEN unplug the computer from power, follow Anti-Static Precautions, and Physically plug the graphics card into the motherboard, and install.
3) L@@k at the system requirements (Minimum) for the graphics card.
Specifically the Power Supply requirements. You need a Power Supply with enough Wattage, to handle the graphics card.
[ Handles the graphics card, and -> Motherboard, Processor, Ram Memory, and peripherals; Internal and External.
{Harddrive/s, optical drive/s; Internal
Mouse, Keyboard, external harddrive, etc; External ]
For additional questions please post in a Comment.
Regards,
joecoolvette
2helpful
I want to buy a graphics card. i want to run programming applications and games with graphics requirements (NFS series), HD support will do but not necessary. My current system : 3.06GHz P4 HT processor,...
The GeForce FX5500 is an AGP Card (which is WAY outdated). Your board has a PCI-Express x16 slot (which is a good thing) so if you are planning to play games in the ilk of the NFS series, you can get an nVidia GT, GTS or GTX series card (I only assume you plan to get an nVidia-branded card; you still have options of purchasing ATI 4000- to 5000-series cards as well). these cards serve the purpose of entry-level to mid-range games. The only limitation of your rig would be the processor since it's a single core; but with 3 GHz & 2GB of RAM, you can play almost the entire NFS series up to Undercover, Shift & World. I'm not sure about Shift 2 & The Run: I think they require 2 cores at least.
Catch reviews with tech specs & side-by-side comparisons of existing video cards at GPU Review.
Can i play age of empires III with radeon7000/radeon ve family
These are the oficial requirements:
  • Microsoft® Windows® XP
  • PC with 1.4 GHz equivalent or higher processor
  • 256 MB of system RAM
  • 2 GB available hard disk space
  • 32x speed or faster CD-ROM drive
  • 64 MB video card with support for hardware transformation and lighting required
  • Sound card, speakers or headphones required for audio
  • Microsoft Mouse or compatible pointing device
  • 56.6 Kbps or better modem for online play
  • So judging by the listed above you could play, but set the graphics detail to medium first and if the game moves in slow motion, set them on low details.
    If you need further assistance, just post a comment.
    I want some information about Nvidia GeForce 9400 GT 1GB DDR 2
    If you are using Dual Core the mother board you are using may have PCI Express Slot. So that you may install Graphics card. Only for particular lower end mother board doesn't have this feature. Any way tell me your motherboard make and model no. e.g., Intel DG31PR, 945GNT, DG41TY etc.,
    1helpful
    I have procesour -- AMD 64 X 2 athlon motherboad -- asus M2A VM HDMI ram --- 4 GB ddr 2 (800 fsb) hd --- 500 gb which grafic card should i buy
    any ati radeon direct x 10 cards will do nicely ....depends if you play games ,work as business, or use pc for media..
    media and games are more demanding so spend more on a better card.
    especially the hd range.
    ok
    Upgrading processor
    Sell this system on eBay asnd buy a new one from Dell or HP as the price of the processor and the ram plus the installation charges will be higher than you Buy a new one with that configuration or Better
    Trust me
    1helpful
    Playing CRISIS..
    heres more info on the game
    http://en.wikipedia.org/wiki/Crysis
    Operating System - Windows XP or Windows Vista
    CPU Minimum - 2.8 GHz or faster for XP, 3.2 GHz or faster for Vista
    cpu Recommended - Intel Core 2 Duo @ 2.2 GHz, or AMD Athlon 64 X2 4400+
    Memory - 1 GB RAM for XP, 1.5 GB RAM for Vista
    Recommended - 2 GB RAM
    Hard Drive Space - 12 GB of free space
    Minimum Graphics Hardware - 256 MB video memory, NVIDIA GeForce 6800 GT/ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater
    Recommended - NVIDIA GeForce 8800 GTS 640MB or ATI 2900XT 512MB
    Sound Hardware DirectX 9.0c compliant card
    2answers
    My hardware upgrade
    all your using is outdated only you can use is your 40gb hdd for a new mainboard. your can go with intel core2duo cpu with ddr2 800fsb 2gb ram.
    Top XFX Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ADMIN Andrew
    ADMIN Andrew
    Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
