If the fans are running too slow, it'll shut down. it needs the fans to run at a certain speed to get enough cfms to ensure proper cooldown. if one is lagging, the lamp or power supply may not cool enough and cause damage. find out which one.
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Unexpected shutdowns could be an overheating problem.
OK, the thing is, if the fan is not rotating at all, you will need to replace it. The problem related to the computer shutting down, is the fact that the CPU overheats, and then shuts down the computer to protect the system components.
SO, if the fan actually rotates, you will need to clean the fan from all the dust particles collected on it. If the fan does not rotate at all, you will need to replace the broken fan.
This would be the fan on the motherboard (CPU), not the Power Supply Unit fan on the case. It may be that it is simply clogged with dust. The PC will shutdown as a precaution to prevent damage to the CPU if the fan has not started or if the CPU begins to overheat as a result of a failed or poorly performing fan.
A overheating CPU will shutdown and won't start up again until the CPU has cooled down. The
overheating problem (ie. thermal shutdown) is most likely caused by a
faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
The CPU is shutting down because it is overheating (ie thermal shutdown) and won't boot up again until it has cooled down. If this problem is not fixed, eventually the CPU will fail completely.
Check the CPU fan to see if it spins freely. Also check the power supply fan to see if it spins freely. If the CPU fan has failed, then replace the CPU fan. The CPU fan and heat-sink assembly may be clogged with dust, if so loosen the dust and vacuum to remove the dust.
If the laptop shuts down and won't boot up again until it has cooled down, then the laptop is overheating and causes the CPU to shutdown. If this fault is not fixed then eventually the CPU will fail.
The fan may not be covered with dust, but did you check the heat-sink?
The heat-sink fins maybe clogged with dust.
Check the fan, does it spin freely, if not the fan maybe faulty and needs to be replaces.
If the Toshiba shuts down and then cannot boot up straight away until it has cooled down, then you could have an overheating problem.
This is caused by a faulty fan and/or dust blocking the heatsink/fan assembly.
When the CPU overheats it goes into a thermal shutdown, and if you continue to ignore this problem, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the fan, if the fan and heatsink/vents are clogged with dust then loosen and remove/vacuum the dust.
Systems that shut down after being powered on can point to an over heating of the CPU. Other factors come into play with overheating. Too much dust build-up on & under the CPU fan blades. Dust builds up in-between the heatsink fins (Thus the CPU fan can not cool the CPU chip.) The CPU fan may be running too slow. When the PC system shuts down it’s saving you from hurting the system. You did not list the model number of you're system. Check you're system & clean the mentioned parts. Use canned air & a dry clean small paint brush to help remove possible dust buildup blow the dust away with the canned air.
