SOURCE: door lock assembly broken, rod assembly fell apart
There is a cheap plastic retainer on the end of the rod that holds it to the handle. Get a Wheel color from a RC airplane hobby shop and use it to hold the rod on the handle. Works better than the original clip. You don't need to take the door apart for this, you can usually reach the rod after removing the interior latch handle.
SOURCE: Need diagram for Mazda b4000 brake drum assembly
Okay, then you have what you need. Just take the drum off of the other side and use it as a reference. You are going to have a hard time trying to find a diagram. The Hayes and others are just general pictures and not necessarily what is on your specific vehicle. I do not have that particular diagram myself.
Please remember to rate this fix.
SOURCE: 2005 ford escape assembly diagram for the front axle
If they are sealed bearings, you will need a press to get them out. If they are bolt in, just remove the brake pads/rotors, then the axle nut, then the bolts holding the wheel bearing in. Install in reverse order.
SOURCE: REPLACING LOWER BALL JOINTS ON 2000 FORD F250 4X4 7.3L DIESEL
hello,yes you do have to take the hub off to replace the ball joint with the ball joint being on the back side of the hub. hope this helps and please rate this.
SOURCE: 2000 lincoln ls bad ball joints! should i replace whole knuckle or just ball joints
yes you can buy just the ball joints
