Question about Zenith Televison & Video
A VHS tape is stuck in my player. How do I get it out?
A VHS tape is stuck in my player. This is a Zenith DVD player + video cassette recorder (model #XBV442). When I push the Eject button I hear the tape being transported to the exit door, then a slight thud but the door will not open. How do I get it out?
Incidentally, I've looked through the manual's Troubleshooting guide with no success.
Posted by Jim Sheahan on
Anonymous
  • 217 Answers
The tape might have stuck inside.. you need to open it and remove it on your own.. if you think its risky go to any nearby shop of electronics.. they will do it for few bucks..
Posted on Jul 10, 2009
Zenith turntable/cassette player/8 track. Serial # 934l4, Can't tell if the model # is IS 40 81-3 or 1 S (Or 15 4081), made in Taiwan. Wondered what age it is and if there are tubes inside?
Cassette tapes began to supplant 8 track in the mid 70's, so this is probably a transitional unit. Kind of like now - there are DVD players out there that still have VHS slots. I'd say late 70's and I'd guess no tubes.
Jul 28, 2017 | Zenith Audio Players & Recorders
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
Can i record a video from a vhs tape to dvd using my zenith? what disc should i use?
no you can record dvd to vhs but not the other way around as the dvd unit is a player but not a recorder
Nov 22, 2009 | Zenith XBV442 DVD Player/VCR
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Vhs to dvd burning
You cannot burn a DVD on the XBV243. It is NOT a DVD recorder. You CAN record onto a VHS tape from a DVD (copy-protected commercial DVDs cannot be recorded)
May 18, 2007 | Zenith XBV243 DVD Player/VCR
Televison & Video Logo
341 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
