Panasonic SC-HT830V System Logo
Question about Panasonic SC-HT830V System
SC-HT830V I have SC-HT830V and the light in the front unit are out, I can't afford to pay $ 70.00 for the diagnostic, Any suggestions and is this something I can fix, if I can order the parts myself
Posted by akukeval on
John Wardlow
    Habit-Forming:
  • 27 Answers
Try shorting across this fuse protector (looks like a resistor) on the power board. See more detailed solution in this forum for a similar question.SC-HT830V - 4a63623.jpg
Posted on Jun 06, 2010
Ismael Lopez
  • 31 Answers
You have to open the unit my friend and behind the front panel there is two flexible connectors, this have a lot of metal connectors inside each. if you remove the panel, try to clean the connectors and close again carefuly. becose are very delicated.
also i have the spares but i live in uruguay so maybe is expansive send that to you.
Posted on Sep 19, 2009
Panasonic sc-ht830v \r\n I could not find a fuse
for as long as they have the same ampere rating that won't cause a problem
3helpful
SC HT830V PANASONIC DISPLAY LIGHT DONT COME ON BUT EVERYTHING ELSE WORKS
Try shorting across this fuse protector (looks like a resistor) on the power board. See more detailed solution in this forum for a similar question.4a63623.jpg
5helpful
PANASONIC SA-HT830V EVERYTHING SEEMS TO WORK
Try shorting across this fuse protector IP1280 (looks like a resistor) on the power board. See more detailed solution I posted in this forum for a similar question.4a63623.jpg
I WANT TO KNOW HOW TO CONNECT MY PANASONIC MODEL SC-HT830V HOME THEATER SOUND SYSTEM TO A SHARP AQUOS MODEL LC-37D62U TELEVISION I NEED A WIRING DIAGRAM
U do not need a diagram-simply hook up red/white wires from audio output of sharp tv to audio input(tv) of panasonic unit.any questions contact us- [email protected]
F61 appears on my setero when i push play
my dear friend. this error message means something is broke on the audio power.
the unit give that message when the chipset find fix current or signal on any audio channel.
the most common means you have to change the audio amplifier unit. sorry but i know is the true.
SC-HT830V connect to cable box Explorer 8000HD
1-connect your cable plug to(rf in)in your panasonic home unit.
2-press up and down arrow and select(antenna setting)and press enter.3- go to cable tv and select it.
No light in front panel
You may be able to fix it yourself. Search this forum or my profile for a more detailed solution to the same question worded differently, it is the one will a lot of photos. Try shorting across this fuse protector IP1280 (looks like a resistor) on the power board. See more detailed solution I posted in this forum for a similar question.4a63623.jpg
My panasonic SC-HT830v DVD/VHS Home theater... Dvd drive will not open or close
try to apply a good brand contact cleaner(from radio shack or other electronic store near you)and press it many times.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
