Question about Samsung 510N 15" Flat Panel LCD Monitor
NOT OPTIMUM MODE
Suddenly I am getting NOT OPTIMUM MODE with my monitor
Posted by Balachandar D on
  • 4 more comments
  • Anonymous Dec 13, 2007
    checked the power supply and all.
  • kkkkiran Dec 21, 2007
    ERRORON SCREEN: not optimum mode: optimum mode=1024X786 60hz
    Monior turns blank
  • Anonymous Jan 02, 2008
    I got the same problem
    un-plug the power cord & VGA cord (5-10 mins)
    and then re-plug again, the screen back
    but this is not a long time solution
  • acamin Mar 26, 2008
    I have the same problem if any one have the solution then give us
  • Anonymous May 10, 2008
    when ever i turn on my PC, there occurs the display poblem saying not optimum mode.
    wheneven i turned on th PC, display problem occurs in monitor saying not optimum mode. and unpluggin of cable is not helping this problem
Anonymous
    New Friend:
!!!! IMPORTANT POST !!!! !!!! IMPORTANT POST !!!! !!!! IMPORTANT POST !!!!
I WILL BUY EVERY SAMSUNG LCD MONITORS WITH THE ERROR : NOT OPTIMUM MODE
CONTACT ME ON [email protected]
Posted on Mar 05, 2010
Anonymous
A PTC is a resistor that is used to demagnetize a Color Ray Tube. I do not know if a LCD screen has to be demagnetize too.
Posted on Jul 19, 2008
Anonymous
What is the PTC component ? pls explain?
Posted on Apr 04, 2008
Anonymous
Hi Guys
Same problem, The best way I found getting around it is to unplug the power for couple of seconds, replug it. Screen starts up with wrong resolution. So I reset set the resolution to 1280 x 960 , 60Hz. If i set it to recommended, the problem re-occurs. Screen looks acceptable on my 15" with 1280x960. Just trying to safe some cash to buy a nice big screen for editing in the future so this solution works well for the moment. Oh by the way I am running the screen from my MackbookPro. It helped to sort out the problem cause I mirrored the displays so I could see what I was doing while figuring it out.
From now on I'll power down the screen+unplug properly every time it's not in use.
Posted on Mar 15, 2008
Anonymous
SAME WITH ME GUYS, I THINK THE COMPONENT IN LCD ALREADY BROKEN. MY FRIEND TELL ME THAT PTC COMPONENT IS BROKEN. THE PROBLEM IS I DON'T HAVE THE SCHEMATIC DIAGRAM FOR SAMSUNG 510N. IF WE UNPLUG THE POWER CORD ABOUT 1 HOURS AND PLUG IT AGAIN IT'LL NORMAL AGAIN AND THE"PTC" COMPONENT IS RESPONSIBLE TO THAT JOB.
Posted on Mar 10, 2008
2 Related Answers
Anonymous
  • 56 Answers
SOURCE: NOT OPTIMUM MODE
you just reset the setting of your monitor just try look the manual for your guide to reset the default setting.
Posted on Jan 28, 2008
AnneFtl
  • 3 Answers
Solder a 50 ohm precision resistor between pins 5 and 6 of the Novatek NT68F63LG
I had this same problem on 3 Samsung 710N displays and this fixed the problem.
I have read others have also been successful but the value of theresistor was slightly different in some cases. I would start with 50ohms as that seems to be a common value fixing most displays.
Here is the reference URL to the ORIGINAL person that solved the problem.
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
Posted on Dec 12, 2008
Not optimum Mode Recommended Mode: 1400X900 60Hz
Hi and thank you for using fixya:
This type of monitor does not has optimum mode
Thank you
Mar 30, 2010 | Samsung 923NW 19" LCD Monitor
Geen beeld opmerking :not optimum mode
comes on and screen says optimized mode 1280x1024 60hz i put it on and get no video
Jan 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
I have the same problem. I get a box with "not optimum mode. But what I need is a picture of the mainboard with the 50 ohm resistor between pin5 and pin6.
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und
Sep 14, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
NOT OPTIMUM MODE
Jan 28, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Showing "not operating in optimum mode"
reinstall the display drivers in safe mode this you can do by pressing F8 and in safe mode, you can also try restoring the machine to previous state Good Luck
Jan 19, 2008 | Samsung 710V 17" LCD Monitor
Samsun 710v not optimum mode problem
you must chang your Mainboard for LCD to fix it
Oct 03, 2007 | Samsung 710V 17" LCD Monitor
Samsung 510N 15" Flat Panel LCD Monitor Logo
999 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
