Remove the paper tray so you can get at the paper. The paper tray will come out usually by gently lifting and pulling.it out. Try to grab the paper in the middle not by a corner so you don't rip it. Then gently pull it back out.
The printer will show a jam until you insert the tray again. If that was the only piece of paper it will be ready to print fairly quickly as the printer restarts itself.
Paper jams can be caused by quite a few things such as humidity after it rains making the paper stick together. Or the paper is too slippery and the printer can't grip it enough to pull it through. One of the basic things you can do to cut down on this happening is when you replace the paper in the feed tray you should "fan" it. All that means is that you hold one end of the paper and wave it like a fan. The other end of the paper stack will fan open between the sheets and helps to prevent them sticking.
Your printer owners manual should have a section on clearing jams and how to fan paper to prevent them. If you don;t have it just go to www.hp.com and go to support and look for your printer. Or search for Officejet Pro L7680 Manual You should be able to download a pdf version of the manual. It tells you how to do things like remove the tray load paper, change ink cartridges and so on. Not exactly an exciting thing to read but it does save you a few headaches.
Paper tary should come out not for sure, I have a Brothers HL-2140 when my printer get a paper jam I have to remove the toner cart, to get the paper out then press the start botton for it to print, Hope this helps you some
SOURCE: Paper jam.
first try unplugging the printer, then take the paper tray out, the toner cartridge out, open the back cover and inside the back cover near the power cord is a blue lever. Try pushing this down as you see if you can remove the jammed paper.
SOURCE: Paper feed problem from both tray 1 & 2
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
SOURCE: I have a paper jam
On that printer, you can't pull out the main tray. This video shows how to clear a paper jam on the C7280.
SOURCE: HP 4700n Paper Late Jam
duplex area related jam in other printers. is problem only occurring in tray 1. If so, there is a problem with the tray. If it's happening from tray 1 and tray 2, replace try replacing transfer belt.
