Question about Car Audio & Video
Problem w/ Orion HCCA - D5000 Amplifier
On the amplifier, the red light keeps blinking, and the amp never comes on.
Any suggestions? or solutions?
  • 53 Answers
Try checking the wiring configuration from your sub to the amp, if the resistance is too low it can cause to go into protection mode or the amp is damaged and you will have to get it service
Posted on Jul 11, 2009
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Power-supply circuit for Orion hcca d5000
send it out to a professional. you need many precise metering tools to measure if everything reads ok, you need to replace other pieces that may not show physical damaged.
Oct 11, 2013 | Orion HCCA-D5000 Car Audio Amplifier
I just got my PPI dcx 300.2 amp back and i hooked it all up, and connected the fuse back in and started the truck, the amp turns on but the red light starts blinking and says clip out. The amp doesnt smell...
Are you sure everything is correctly connected. If you are running the amplifier in bridge mode then take note that the load to the amplifier can be no lower than 4OHM. dreamsystems
Feb 25, 2011 | PPI DCX-300.2 Car Audio Amplifier
I have a orion hcca d5000 and keeps going into protection. there is nothing hooked up except power, ground and remote. I hook amp to a bit writer and it reads over current. Can this be reset, or is my amp...
yes mines does the same and everyone keeps saying check the ground upgrade to the big three and so on personally i think this series and there new amps are just junk. Mines been in protect since i got it two years ago, once inawhile would turn off with big bass drop and now the amp doesnt really work in master switch but works on the slave i just think the amp was built poorly so, my advice get it bench tested before you do any new upgrades
Sep 02, 2010 | Orion HCCA-D5000 Car Audio Amplifier
My visonik v700hc keeps going into protect modeafter listening for a couple minuits then will go green light then back to red after a coupke more any solutions
I suggest checking what ohm load you're presenting to that amp. go to www.the12volt.com and find the subwoofer wiring diagram and choosing the amount of subs you have on it and then the impedence of each one. you're probably sending too low of an ohm load to the amp this would cause it to go into protection quite frequently and eventually stay in protection.
May 30, 2010 | Visonik V700HC Car Audio Amplifier
The saftey red light keeps coming on
It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Nov 18, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Blinking red fault warning
timy check the speaker conections before condeming the amp
Apr 30, 2009 | Crown CTS600 2-Channel Amplifier
Behringer EP2500 trips immediately when turned on
Power supply section is overloading probably because of audio power amp problem.
Paul
Mar 31, 2009 | Behringer EUROPOWER EP2500 Amplifier
Car Audio & Video Logo
307 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
