Question about BenQ FP731 17" LCD Monitor
BenQ FP731 17" LCD Monitor Problem
My BenQ monitor has a black screen. The power light goes on, but nothing else!
Posted by dbechaz on
  • 9 more comments
  • billy24 Nov 15, 2007
    The screen of my monitor BENQ FP731/FP737s LCD is always blanck even if the light is on
  • indarios Nov 16, 2007
    Im having the same issues, no picture but the light next to the power button will show its status still. If its connected to a computer it shows the green light but when its not connected to a computer its orange. Also for the past month i noticed its making a very high pitch squeal when its on power saving mode (when the orange light is on)
  • Anonymous Nov 30, 2007
    Exactly the same thing for me.
  • Anonymous Dec 04, 2007
    i was in the computer searching then my screen turn to black everything disappear, then i touch the mouse it never went back so i turn off my computer then i put it on back but still my monitor screen is black
  • pkcanada Dec 26, 2007
    I have the same problem, monitor light is on but no display, the amazing thing is my monitor just passed the 3 year warranty and display is gone.
  • Anonymous Jan 14, 2008
    same situation... 2 months past 3-yr warranty... 2nd BenQ... same model... slow to display... no doubt on its way out too... if you are handy try: http://www.lcdrepair.us/index.html they have videos which clearly show how to replace the inverter-power card... no soldering required.
  • Anonymous Apr 14, 2008
    lol, it seems BenQ really tried to create this situation. My warranty just expired two months ago.
  • Ugurhan Akturk
    Ugurhan Akturk Apr 30, 2008
    If I let the monitor on no problem. When I turn the computer off turn to booth on screen comes on momentarily and turns off I had to turn monitor on and off probably more than ten times to get the monitor to stay on. Once it is on it is ok.
  • Anonymous Sep 06, 2008
    light is on but the screen is black. [email protected]
    Benq FP731 Serie Q7T3 built in 2005,3 years ago.
  • gordon johnson Oct 07, 2008
    I had the same problem//checked all 4 c5707 good,then checked a few other parts before i found the pf751 open ,replaced it,not with 3amp fuse, but a 2.5amp fuse found on old crt comp.board.working ok now
  • aricappa Nov 14, 2008
    IF I SWITCH ON THE MONITOR WHILE THE PC IS ON OR OFF THE GREEN LIGHT QUICKLY FLASHES....... ALWAYS!
    THANK YOU
    aricappa
Anonymous
Had the compete dark screen problem. Green/amber power light was coming on and off as expected but no image would appear on the screen.
Found PF751 to be open.
Thnaks for the help people.
Posted on Oct 08, 2008
Anonymous
    Problem Solver:
  • 3 Answers
Hi, after changing the transistors, you got too check the four transformers legs for cold joints. If not the new trans: blow out again.
let me know.
Posted on Sep 19, 2008
Anonymous
I tested this camera for a client. I didn’t have the light running for more than 15 minutes. The battery lasted approximately 6 hours before recharging. The LCD, however, had a few dead pixels - never saw this before. Tried returning for exchange and had to put up quite a fight. Anyone else seen this? http://www.batteryfast.com
Posted on May 28, 2008
Anonymous
    Problem Solver:
  • 8 Answers
Spot on! I has a FP737s-D. Q758 had blown. On top it looked like a black texta mark, but on closer inspection that transistor had a mico hole where the plastic had blown out. Underneath, was a dry joint. Benq are nice, in that the shade of green was darker, indicating heat. As Both transistors are a pair, replaced both. Lightening strike did the damage.
Posted on May 11, 2008
Alexander juico
  • 89 Answers
Its a problem with the inverter. check the 4 transistors, C5707 near the connectors for the backlight. If none are defective, look for the PF751 FUSE. It sure to be busted.You can replace that with another 3A fuse. Remember, you should only replace the fuse if you are certain there are no busted transistors in the inverter board. Otherwise, you now have a refurbished Benq Monitor
Posted on Jan 07, 2008
Anonymous
    Scholar:
  • 116 Answers
Connect it to another device, if you get the same result the backlight is bad! These can be replaced, but can be costly!
Posted on Nov 26, 2007
  • Anonymous Nov 29, 2007
    Well I am sorry this did not help you! Inappropriate! Wow I need to look up the definition!
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Apr 16, 2008 | MPC Computers AOC 7F 17" CRT Monitor
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq LCD monitor
I had same problem. No Power at the monitor. what can I do?
Jan 03, 2008 | BenQ T705 17" LCD Monitor
Benq FP71G+S NOt starting.
Hello
I have had this problem twice once at my school and once with my BenQ FP71G Monitor. At my school the monitor ( HP ) just stopped working and smelt like burnt popcorn.(though is think this is due to some kids chucking a soccer(football) ball at it! With my BenQ it has the same problem though i nownthink it is because of the monitor has been on for excessive hours ( 3-4 ) and just shut down because of overheating. I will see in a couple of hours if it works !
Copper_R
Dec 30, 2007 | BenQ FP71G 17" LCD Monitor
My ben t705 moniteur.... problem
I DID REPAIR A MONITOR WITH THE SAME PROBLEM. IT TURNED OUT, THAT ONE OF THE TWO HIGH TENSION GENERATORS FOR THE 2 LIGHTTUBES WAS BURNED OUT. BY REPLACING THE POWER TRANSISTORS AND THE 3 AMP. FUSE ON THE MAINBOARD THE MONITOR IS RUNNING AGAIN VERY WELL.
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Monitor goes black
I also had an issue with a Benq FP731 monitor. They have a 3yr warranty so my suggestion is to send it back. You have a IC on the inside that is getting ready to go out. You have to call them and get an RMA and pay for shipping out to them, but they ship back on their dime.
Aug 29, 2007 | BenQ FP71E 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
1,319 people viewed this question
Top BenQ Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
