Microwave Ovens Logo
Posted on Jul 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microave does not turn and heat. the light comes
Microwave does not turn and heat. the light inside comes on only and the timer is going but not turning the turntable and not heating
Anonymous
Level 3:
  • Master 456 Answers
  • Posted on Jul 12, 2009
Anonymous
Master
Level 3:
Answers
456
Questions
Helped
107506
Points
1224
Replace the magnatron assy and the high voltage fuse.
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
2helpful
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
MICROAVE JUST SHUT DOWN, REPLACED FUSE, MICROWAVE WORKED FOR ABOUIT A MINUTE THEN SHUT DOWN AGAIN, ITS KEEPS BLOWING THE FUSE. IS THIS SOMETHING THAT IS REPAIRABLE OR JUST NEEDS TO BE REPLACED?
It is one of three things, the magnetron "heats food" or the high voltage capacitor, and diode. If the magnetron is gone, cheaper to replace the microwave, as far as the other parts go, it will approach the price of a new one.
Will not heat up but it turns on and runs
the light won't come on how can i get the light bulb out?
My Frigidaire microwave wont heat up but the timer and lights work. When i press start, the timer starts but there is no sound and it doesnt heat. The microwave is less than a year old.
this may be another bin job, if its not heating up its likely to be the megotron,, thats one of the pricy bits that go out like a light bulb, ask if your shop sells the tester that you put into the microwave to see if its pushing out any radition at all, if its not i would bin it and get a new one, dont try fixing it yourself,,,,,,
you could kill yourself, there is well over 1000 volts floting about inside the unit, tuch the wrong bit and you grow wings prity fast, be warned
Kenmore Galaxy Microwave Hood Combo Model 72180002400
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
11helpful
2answers
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
1helpful
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
Microwave not making any sound, or heating. control panel works!
This microwave probably has a serious electrical problem...a defective magnetron or rectifier. It should probably be checked by someone who is familiar with electrical repairs...there can be high voltage inside and a danger of electric shock, even when the oven is off.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
