Question about Samsung SyncMaster 753S 17" CRT Monitor
Monitor not switching on.
Last couple of days I used the Samsung syncmaster CRT 17" to watch movies, all of a sudden i was not able to switch on the monitor.
Initially when I used to switch on the monitor, i used to hear a sound, i think some kind of capacitor charging. But, now the sound has faded away.
and I cannot switch it on.
Posted by Meghashyam on
  • 2 more comments
  • delmas Nov 16, 2007
    • 735s crt dead
    • Replaced IC601 (now in DP704C)
    • Replaced zener diode ZD 601 (now in 30v)
    • Replaced resistor R609
    • When switched on it starts,can hear relay switch,hear degausing coils but sparks coming out underneath lopt. Is transformer faulty or some other components causing it.
  • Anonymous Dec 30, 2007
    Sync753s Monitor power switch problem.
    I have to press monitor power switch atleast 5 to 10 times to to on my monitor.
    How to solve this problem ?
  • Anonymous Feb 04, 2008
    led no light
  • Anonymous Mar 26, 2008
    i am not getting any sound out of my samsung monitor. i see some sort of a plug socket with little dots on it, is there supposed to be a plug for it for the sound?
Anonymous
  • 180 Answers
It is the Horizontal Output shorted or the primary coil of FBT might have shorted.
Posted on Apr 19, 2008
Anonymous
I have to press monitor power switch to on my monitor, but occasionaly it works. Once On without any problem it is working. What will be the problem.
Posted on Jan 07, 2008
Anonymous
I have to press monitor power switch atleast 5 to 10 times to on my monitor.
If you have solution please mail me to [email protected]
Posted on Dec 30, 2007
Anonymous
  • 170 Answers
Hi, the crt(cathode ray tube) that is the display of your monitor has been damaged.
nothing happens to your monitor if you watch movies.
tips to keep your monitors longlasting;
1.do not keep UPS next to the monitor
2.do not keep speakers next to the monitor
3.do not keep any device that has magnets or electromagnets in it.
bye take care & have a nice day.
Posted on Nov 14, 2007
I am using my samsung monitor (SyncMasterfor half a day now and all of a sudden the clear display started to be blurred with blue. I don't know what to do ? kindly help...
If it has turned blue, it is most likely that the cable has become loose. Try tightening the cable at the back of the monitor as well as the PC.
If you continue to see issue, try switching the cable with a new one.
Feb 28, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
NO Display
time to replace the monitor, u fried the board, been there done that
Jun 20, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Screen menu auto-adjust ghost
never try to fix crt monitor you need a new one cos thay are so cheep cost you lots for reppers ,bye an lcd ,,,,nice
Apr 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung 753s monitor problem
try to check the B+ line voltage. Check the FET and resistors on this line.
Mar 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Blurred images at start on samsung monitor
This is CRT Base Problem Simply Replace it
Thank You
Mar 09, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
SAMSUNG MONITOR 753 SWITCHING PROBLEM
Problem can be dry solder or dfective switch.Try switch cleaning using WD-40 or similiar solution.
Jan 31, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
315 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
