Question about Panasonic SC-HT830V System
I have found the solution to this problem. There is a big diode on the circuit you can miss it. Ithe number on the diode is 31DQ04 this diode gets shorted out. therefore the display won't light up. Go to radioshack and buy the the following number 276-1143. " rectifier diode" this is what the diode is doing it is rectifying the AC into DC. the problem should go away!!!!!!
It is not the fuse protector. The fuse is not the problem. I hope this helps.
Posted on Jun 25, 2010
Check little yellow fuse (ip1280) on the supply pcb. I believe it's rated @400ma.
Posted on Mar 10, 2010
How to add a Switch to Power on and Off HT830 . I just want to use this with my home Stereo System. Is there a Jumper to Install to bypass the CN 501 Socket
Posted on Jun 28, 2012
my friend, this display have flexible connections to the main socket, so i think you have to open the unit and clean the connections and close again carefouly cose this is ver delicated. ask me more help i do thi before
