That is the starter key line!
so at the starter solenoid, pull off , the tiny wire lug there.
no more blow?, the starter solenoid is bad shorted.
yes, blows, then the key line is shorted. (harness shorts or)
is car stick or auto shifted, ? as both wiring is different.
in a real shop we have this $50 meter, that allows me to find
shorts fast. (amp clamp meter , DC)
or this. dirt cheap. $20
http://www.fixkick.com/tools/25100.jpg
this one works 2 ways, a meter and CB ,it has a circuit breaker
to replace your blown fuse. then not going broke on fuses.
finds any short, even on harness shorts.
You have a short to ground somewhere.The best way to start this diagnosis is you will always have one of your main power wires of your battery to the starter.A better question is do you even get to crank it before it blows or does it blow when you put it in, as in turn the key to the run position no cranking or you crank then it blows?
SOURCE: location of cam position senor
Not a bad job to replace the cam position sensor, it took about two hours cost about $150.00 with oem parts. First remove air filter box,remove plastic spark plug cover. Jack up engine about an inch remove engine mount. Now you can access sensor through a convenient cover that mounts around engine mount bracket extending from engine block.( one ten millimeter bolt) Remove accessory drive belt for a little extra room and replace with new one while you are in there. Just between the two cam gears you will see a torx screw that aligns the switch when in installed. DO NOT REMOVE THIS Just above the torx screw is a reverse torx screw (6 millimeter) Put a shop rag in the access hole to catch the screw just in case you drop it ,( so it does not fall into timing belt cover) Put something "sticky" in the 6 millimeter socket such as gasket sealer to keep from losing screw. remove. Pull switch up from inside spark plug cover and install new one through the same. reinstall 6 millimeter bolt. Switch is self aligning. Reinstall belt, engine mount, air box. Doing this myself probably saved me about $150.00 to $200.00 dollars
SOURCE: 04 Tahoe blowing fusible link in fuse box for starter
HI...
ON the fuse box cover.
IS there a especification for the funtion of the fuse. or the number of the location of the fuse.
If you can give me, I can try help you. as more I can.
Thank you for use fixya.
SOURCE: can't find the fuse box 2005 suzuki forenza wagon
THERES A FUSE BOX THAT SITS INSIDE THE HOOD OF YOUR CAR BY YOUR BATTERY AS WELL AS ONE BY THE SIDE PANEL BY YOUR DRIVER SIDE. EITHER SPOT SHOULD HAVE A FUSE THAT GOES TO YOUR RADIO. I HOPE THIS HELPS YOU!
SOURCE: 04 SUZUKI FORENZA DIES WHILE DRIVING
Several things can cause a car to die. The fact that you don't have any engine codes eliminates some of them. First thing you should try if you haven't is change the fuel filter. Make sure there are no damp, or damaged electrical components. It could be faulty spark plugs, or wires, or a vacuum leak. Check carefully under the hood for vacuum leaks. With the engine running, wiggle all the vacuum hoses around and check for cracked loose or broken hoses. They will make a hissing sound when you find it. A stethoscope, or a length of fuel line held to your ear can help a lot. Check all intake bolts for tightness too. Good luck.
SOURCE: power steering light on 2006 suzuki forenza
Power steering light?? Maybe it's something else.
