Refrigerators Logo
Posted on Jul 10, 2009
LG refrigerator - Need help replacing a part in the door.
I need to replace my ice/water dispenser funnel. To do that I have to install a new funnel frame. How do I get the cover off the ice dispenser funnel/frame in the front door so I can replace the parts?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 25, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
717
Points
How to install part ac110-115v for lg refrigerator
5 Related Answers
Anonymous
  • 291 Answers
  • Posted on Nov 03, 2007
SOURCE: Ice and Water Dispenser Funnel
This diagram may help some.. should be a molding thats goes around outside of dispenser.. should be able to pop off and get at screws u need to get at...to remove and get at what u need too
http://www.partselect.com/Schematics/GE/00116598i01.gif
Anonymous
  • 145 Answers
  • Posted on Apr 24, 2008
SOURCE: Whirlpool refrigerator ice dispenser
The front cover is snapped on. There should be two slots in the bottom of the cover. Put a wide screw driver in the slots one at a time and pry out. It snaps off very hard.
Anonymous
  • 410 Answers
  • Posted on Feb 18, 2009
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Anonymous
  • Posted on Jan 05, 2010
SOURCE: LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Anonymous
  • Posted on Jul 29, 2010
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
I had the same problem with our Whirlpool Gold. Which by the way was just out of warranty. The guy who repaired the problem told us that since there were so many replacement dispenser motors at different supply locations that there must be a problem. I think that the root cause is the arm in the ice holder is hard to move, and it burns the dispenser ( #2252130) motor out. Whirlpool should get to the bottom of this and offer free or reduced repairs. Motor # 2252130
No water/ice dispensing
I would make sure all the doors are completely closed. If you can't completely close one of your freezer doors, you may have ice built up behind it. Take your freezer bin out and see if you have to defrost.
Can water/ice dispenser be fixed without replacing door
I really can't imagine having to replace entire door to repair dispenser.
2answers
How do i replace ps 652226 ice funnel ge ziss480drbs
carefully removed the trim from around the dispenser area by gently prying the trim off careful not to brake it. then freed the catches in the top of the electronic card. I leaned the card forward and disconnected the electrical connections, then removed the card. I removed the four screws holding the shield to the door and removed the shield. Then I removed the funnel from the shield and removed the spring from the old funnel and placed it on the new one. I removed the light and socket from the old shield and installed the in the new one, then installed the new funnel on the new shield, used the four screws to install the assembly on the door and replaced the trim piece. Here's a DIAGRAM to help.
Our LG fridge had an issue where the water supply was cut off, so the ice cube maker stopped working as well as the water dispenser in the front. The water valve was replaced, and the ice maker started...
it could be a frozen water tank inside freezer door. if so, door will need to be replaced; as, there was maybe a spot where the foam inside door wasn't sprayed properly. disconnect water line fitting under door behind kick plate; close door and try dispenser. this will verify if it's the door or not.
2answers
5helpful
10helpful
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
2helpful
3answers
Lg refrigerator water dispenser would not shut off
so two things I have learned. First if the tabs on the funnel break dont buy a new one just crazy glue back in place. Also if you take the gasket out put vaseline on the nubbins and they will slide back in place without having to take the panel apart. Fix time 7 minutes. Booyah!!!
1helpful
2answers
Lg lfx25960 Ice Dispenser
I had the exact same problem on my LG LRSC26940 and was able to fix it fairly easily. First remove the Ice Funnel by pulling down on it. Then remove the entire dispenser panel by getting your fingernails underneath and pulling out. Disconnect the electrical connecter to the front panel PCB. Remove the 4 screws attaching the bracket that the Ice Funnel connects to. This exposes the solenoid that opens the Ice Door flapper. In my case, the electrical connections to this solenoid were bad. I simply scraped the spade terminals on the solenoid off with a screwdriver and crimped the connectors with a pliers. I put it all back together and it is working fine now.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
